S2000 Naturally Aspirated Forum Discussions about N/A motor projects, builds and technology.
Engine Temps
Old Jun 30, 2013 | 07:34 AM
johngamez10's Avatar
Default Engine Temps
Hi everyone!
I have a 02' with 88k on the engine and 102k on the chassis and everything else. It's been about three months since I installed a AEM EMS version 2 series and upgraded to a 70mm throttle body with a 69mm port-matched intake manifold. I also have a Berk header-back single exhaust installed. So the car is currently tuned. My concern is am I running higher temperatures in the engine with these modifications compared to stock levels? If so, what cooling system modifications would decrease engine temps? I know an effective cooling system will prolong the car's longevity and reliability. I would really appreciate some recommendations on where to start and which parts you recommend.
BTW, old thermostat has been replaced with OEM part when I installed the intake manifold.
Also I plan to add headers and some cams in the next year or so.
Old Jul 2, 2013 | 11:12 AM
s2kt3's Avatar
I'd say get an aluminum rad and slim fans, silicone upgraded rad hoses and an oil cooler set up with thermostatic switch...
that would take care of all your cooling needs !!!!
-Lee
Old Jul 2, 2013 | 11:39 AM
baZurk's Avatar
Wait... are you actually overheating? The stock cooling system is more than capable unless you are tracking heavily.
Old Jul 2, 2013 | 12:01 PM
yamahaSHO's Avatar
Did you change the temp sensor scaling in the AEM? This is a known problem and will report incorrect temps. Ideally, you shouldn't be overheating (normal driving) as the fan is controlled by a switch that does not get input from the ECU.
https://www.s2ki.com/s2000/topic/780...tion-for-temp/
Old Jul 2, 2013 | 01:38 PM
-Lee
Those are good options. How much would an oil cooler setup cost?
Old Jul 2, 2013 | 05:44 PM
s2kt3's Avatar
A good one can run 500-600 bux .... And same for rad... But then u won't have to ever worry bout cooling things down no matter what you throw at the car
Old Jul 4, 2013 | 08:53 AM
GrandMasterKhan's Avatar
a radiator is nothing but bling with your mods. you can buy one if it makes you feel better having it but i can assure you the oem radiator is more than sufficient.
now an oil cooler would be a good idea if your concerned. S2000s are known to run higher than normal oil temps on the track.
save the money you would spend on bling like fancy hoses, and radiators and get an oil cooler. Your money will be spend making a real difference for your car instead of just looking pretty to show your friends when you pop the hood.
Old Jul 4, 2013 | 09:32 AM
wadzii's Avatar
Banned
The ems usually reads a little higher than a scan tool would with the stock ecu. Its not a big deal, use it for reference. See what the temps are with everything working correctly and look for deviation. You can also use an infrared thermometer to see what the temp of the radiator is just to double check.
The ems can directly control the fan, if you have it setup to control the fan the fan switches wont have any effect on things.
Old Jul 5, 2013 | 07:09 AM
Yeah that makes more sense. I always hear people installing aftermarket radiators usually when the OEM rad goes bad. Seems like an oil cooler setup would cost about 1k for everything and installed?
Old Jul 5, 2013 | 09:08 AM
Cody Red's Avatar
If you diy and follow this it shouldn't cost more than $550. I'm fittin' to do that either next or after a custom diffuser project.
Nabu
74
Aug 2, 2017 08:21 AM
johngamez10
Jul 3, 2013 01:33 PM
Danks2k
May 27, 2008 05:27 PM
Superfly05
Sep 28, 2006 09:28 PM
whiteGoKart39
Feb 13, 2003 09:56 PM
