going with larger pistons in an F20 rebuild to gain HP
Its a good compromise. Where id recommend, if longevity of the motor is appreciated. I put approx 80k on an f22 revving to 9k, half of which were supercharged miles and I never had a rod failure, but I think I did prematurely develop some ovalization in the bores from all the added side loading and I did start to develop cylinder scoring and eventual loss of compression. Some of that I think was attributed to a less then idea tune though.
Its 100% pnp, no problems. The F22 due to the stock cams only really is worth revving to 8400-8500 rpms and drops off in power too drastically after that, which is good in a way as its easy to tell when to shift, unless your supercharged, and then it doesn't matter. But there are times on the track where having the over rev is certainty beneficial. In my experience the f22 will take 9k rpms reliably, but it cant be great for longevity compared to stock rev limit. Norule that says you have to bounce it off the rev limiter every chance you get just because you can. 8500 rpm in the f22 is the equivalent piston speed of the f20 at 9k just fyi.
Yes, in theory. Surprising a lack of data on this though. Some say the best combo is to leave the exhaust cam in and just run the f20 intake cam. But I have yet to see a dyno on either.
Increasing the bore size can also get messy since our deck clearance is actually negative (the piston sticks out of the block) so if you go much bigger than the .25mm over the head will probably need to be machined.
I'm going to take some measurements today but I had read somewhere that our CCs were only like 87.5mm wide. I want to run an 89mm bore myself but don't want to have to machine the head for it as the quotes I've gotten for it are really high.
02_s2k
07-19-2014 11:26 AM
buzz944
06-21-2012 02:35 PM
