my f24 309 whp
#136
All of this lightweight internals talk is in vain if your not going to bolt up the lightest flywheel you can find.
The factory F20/F22 engine/ internals are great with an 8lb flywheel bolted up to it.
rednikos (05-11-2020)
#137
I am in the middle of deciding 8 or 11 pound flywheel myself. I leaning towards 8lb to compliment what I did in the rotating assembly.
#138
Thats not true at all. The bearing and wrist pin load are greatly reduced which is the reason i sought to lose mass on the rotating assembly.
#139
If you spend the money and time building a engine with aftermarket lightweight rods and pistons and then bolt up an 11lb flywheel to it instead of an 8lb, you just negated the whole point. Your working against yourself. If you want the engine to rev up and down fast and free the flywheel has just as much influence on this as the internal engine parts, however the flywheel is the low hanging inexpensive fruit and the engine components are the last thing you would focus on because they are the most expensive and have the least amount of weight savings. Period end of story. Just trying to help you out here. Don't waste your time and money on the engine unless your going to take it all the way. If it were me, id leave the stock engine alone and just run the 8lb flywheel, its a beautiful combo I run with no shortage of free revving responsiveness over stock and it will also reduce some load stresses on the mains too. But you have to weigh out your main focus here. The factory internals are capable of 9k rpm for several hundred K as oem designed. You building the engine to take 10k+ rpm? If not, internals are the last thing that should be on your mind.
#140
