AEM EMS and DL1 ECU Cable
Old Apr 12, 2010 | 08:57 AM
Stratocaster's Avatar
Default AEM EMS and DL1 ECU Cable
  • Connect your straight through Serial cable to your AEM EMS as though you are going to program your ECU
  • Launch AEM Pro
  • Connect to ECU
  • Once connected to the ECU, Click Setup -> Advanced -> Telemetry ->Telemetry Setup
  • Change the Parameter Count to 19
  • Change the Header byte to 0x55
  • Verify the Enabled check box is checked.
  • Set the Baud rate to 19200
  • Verify that Parity is set to None
  • Add the following parameters in the following order:
  1. Engine Speed
  2. Engine Load
  3. Throttle
  4. Air Temp
  5. Coolant Temp
  6. ADRC11
  7. ADRC13
  8. ADRC14
  9. ADRC17
  10. ADRC18
  11. ADRC15
  12. ADRC16
  13. ADRC108
  14. O2 #1
  15. O2 #2
  16. Vehicle Speed
  17. Gear Calculated
  18. Error #1
  19. Error #2
  • Click Show Info
  • Verify that the setting match the values above
  • Click OK
  • Click OK
The configuration is now saved the ECU.
Old Apr 12, 2010 | 09:34 AM
rob.ok's Avatar
How come RT didn't know how to do this... I'm actually selling one of these cables cause they could never help me to get it set up and I just totally gave up!!! I really am not happy with them... The products work but everything is ass backwards and the support is terrible!
-Rob
Old Apr 12, 2010 | 10:14 AM
Support is tough thing to do when you cross manufactures products. Each manufacture stops on their own product. But it takes some understanding of how they interface to get things to work across product lines.
I think the problem here is that it requires AEM EMS to talk to the RT ECU cable. That gap is what is missing and not documented at all. I only stubbled on this via a post in the forum that had a screen capture of data that I found in the AEM EMS.
I think RT assumes that we know the EMS. but I do agree, their support needs some help.
Old Apr 12, 2010 | 10:15 AM
Oh, I documented how to do this, and sent it to RT. So maybe the next guy will get better help doing this.
Old Apr 12, 2010 | 12:56 PM
rob.ok's Avatar
Yeah I can understand when your trying to make your product work with so many applications but really is all comes down to documentation. Too bad I sold my EMS... Now I have to pick one up so I can log all that good stuff!
-Rob
Old Apr 12, 2010 | 03:14 PM
I am not sure how much value having the ECU cable. It does simplify the wiring. But there is nothing that you can't get by taping into the existing harnesses. As best I could tell, the ADCR8-18 are useless to me. I may figure out some way to use them in the future, but at this point they add no value.
But with this one connection (ECU Serial cable) I get the following without tapping the harness.
  • TPS
  • RPM
  • MAP
  • Air Temp
  • Coolant Temp
  • O2
sebian
May 29, 2016 09:57 PM
s2kseven
Nov 7, 2012 06:11 AM
YuriArts
Jan 27, 2011 07:04 AM
mys2k3
Mar 29, 2009 06:57 AM
JuanNeeto
Sep 10, 2005 11:08 PM
