Air pump bypass/removeal
Old Nov 5, 2011 | 02:19 PM
  #121
Izze-Engineering's Avatar
Banned
You have PM
Old Nov 5, 2011 | 04:29 PM
  #122
lke2drvgsr's Avatar
Works
Old Nov 13, 2011 | 07:18 PM
  #123
F20Chris360's Avatar
Pretty sure Sportcar motion makes a kit for this too
Old Nov 14, 2011 | 06:05 AM
  #124
Banned
Not quite. I sponsored them.
Old Dec 9, 2011 | 06:48 AM
  #125
DJ8684's Avatar
so this is supposed to take care of the P1457 CEL, correct?
Old Dec 9, 2011 | 08:51 AM
  #126
Banned
P1457 - Evaporative Emission (EVAP) Control System Leakage (EVAP Canister System), has to do with the EVAP system, not the secondary air injection system. The EVAP system gathers, stores, and purges gas vapor from the tank into the engine.
Old Dec 20, 2011 | 09:03 PM
  #127
Driven's Avatar
just installed! Very happy that I can get rid of one more CEL. Although, when I was going about removing all of the airpump crap... I found out why I was getting the CEL for the airpump (disconnected vacuum line). Oh well.
Hardest thing was getting the hard line on the frame rail out of the car. The current sensor was also a pain, since I didn't know you have to take it apart to disconnect the other connector. Saved a whopping 5lbs... now I can go enjoy more Five Guys Hamburgers
Old Dec 21, 2011 | 03:35 AM
  #128
Banned
hahah good to hear
Old Jan 3, 2012 | 12:55 PM
  #129
s2konroids's Avatar
Does this work on EURO cars? I'm in the UK and just seen this.
LOL, Labview used that at work for simulators (the kit is a bit expensive) - its a bit chunky as just C underneath but pretty cool.
Old Jan 3, 2012 | 02:34 PM
  #130
Banned
Sorry, only USDM S2000's. I've already developed a prototype simulator for non-USDM S2000's and am having them tested now. The air pump monitoring system for non-USDM S2000's is very simple, the USDM system is far more complex.
You can bypass non-USDM S2000 air pump by replacing the pump with a 20W, 12 OHM resistor (however, you have to keep the fuse box, relay, and entire wiring harness attached/connected).
LabVIEW is very powerful, I use it all the time for data gathering.
EDIT:
I've been receiving quite a few PM's on where to purchase the air pump simulator. I'm currently an S2ki sponsor, my air pump simulator thread can be found here: https://www.s2ki.com/...ump-delete-kit/
Izze-Engineering
2000-2005 USDM Honda S2000 Air Pump Simulator
Description:
This module simulates the existence of a Honda S2000 air pump system.
If the air pump system is defective or deleted, installing this simulator will eliminate the associated air pump system Check Engine Light (CEL) Codes:
P1410, P1415, P1416, P0410, and P0411.
Over 125 sold with a 100% success rate! Many S2ki members can vouch for this product.
The initial development of this simulator can be followed in this thread: https://www.s2ki.com/...bypassremoveal/
An extensive amount of hard work, time, and money went into developing this module.
Price:
$64.95 Shipped via USPS Priority Mail
Compatible Vehicles:
2000-2005 USDM Honda S2000's
Includes:
-Air Pump Simulator
-Intake Manifold and Air Neck Inlet Vinyl Caps
-Squeeze Connectors
-Zip Tie (mounting)
-Link to Instructions (http://www.izzeracin...nstructions.pdf)
Purchase Here: http://www.izzeracing.com/
Feel free to contact me with any questions via PM or my email: calebh@izzeracing.com
Caleb
