Air pump bypass/removeal
Old Mar 18, 2007 | 11:14 PM
krazik's Avatar
Administrator
yes erik I ran for ~2 years w/ constant cel because of lack of o2/smog stuff. No change in performance.
Blinking CEL is what you need to worry about.
Old Mar 19, 2007 | 10:57 AM
cthree's Avatar
Administrator
Sweet, thanks. What about running without the instrument panel?
Old Mar 19, 2007 | 11:01 AM
krazik's Avatar
Administrator
never tried it, but I've been told it's supposed to work.
Old Mar 19, 2007 | 01:12 PM
alejo's Avatar
Does the blinking CEL indicate only THE problems with catastrophic implications?
Old Mar 19, 2007 | 02:32 PM
Slows2k's Avatar
Blinking CEL only indicates the engine is misfiring bad enough to damage the convertor.
There is still a "limp home" or backup mode the PCM will default to if a CKP/TDC sensor input is lost, or a problem with the VTEC system is found. Expect a 3K rpm rev limit if you loose a CKP/TDC signal and no VTEC joy 95-6K rev limit) when it's trouble code is stored.
Old Mar 19, 2007 | 10:12 PM
cthree's Avatar
Administrator
So long as it doesn't dial back due to emissions related faults. What about the instrument panel? Will it run fine without?
Old Mar 19, 2007 | 11:28 PM
krazik's Avatar
Administrator
I'll disconnect mine when I take the car to tonys and drive it around and let you know.
-Ry
Old Mar 20, 2007 | 04:00 AM
Slows2k's Avatar
Let me check the ETM. Some cars won't charge the battery with the cluster removed.
Old Mar 20, 2007 | 01:52 PM
Ray K.'s Avatar
Originally Posted by Sweeper' date='Mar 18 2007, 09:27 AM
Tell me what the inputs and outputs are and I can design you a circuit board.
Sweep
I would think you only need a resistor. I know some Audi/VW shop sells a resistor in their kit with the plate to block off where the air is pumped into the head.
Old Mar 20, 2007 | 04:16 PM
Slows2k's Avatar
A resistor is not going to duplicate the same current use as a Electric motor, or change 02 sensor inputs..
