Am I that bad?
Old Feb 26, 2014 | 09:47 AM
  #31
boyguan's Avatar
One on each side. What limits the travel of the arm is the length of the shock. You could disconnect the sway bar but since you have to remove the shocks anyways just remove both lower bolts and then install. Install both shocks then install lower bolts
The fronts just remove the upper a arm bolts and it's out. Same thing remove both lower bolts on the shock.
Old Mar 7, 2014 | 04:13 PM
  #32
solos2k's Avatar
It was finally warm enough to work on the car again. I used the factory jack and some wood blocks and it took me about 1/2 hour to do both sides. Thanks again.
Old Mar 7, 2014 | 05:43 PM
  #33
sillyboybmxer's Avatar
wish i could say the same!
stripped the bottom bolt because I couldnt get it lined up. Honda didnt have one in stock so I had to order one,....back at it again tonight. I think the bottom of my oem shock was bent from prying on it to uninstall the first time. Pain in the butt.
straightWORK!
Jul 31, 2013 10:47 AM
chinkieboy
Nov 30, 2011 11:02 PM
espelirS2K
Dec 7, 2008 05:26 PM
SlidinS2k
Apr 16, 2006 11:23 PM
