Assistance w/ Alignment Please!
Old Nov 19, 2005 | 10:29 AM
  #21
PedalFaster's Avatar
You should max out your front camber. I don't think I've ever seen a stock S2000 get to -2 degrees, but if you can, all the more power to you.
Old Nov 19, 2005 | 11:13 AM
  #22
Cone_Killa's Avatar
Thanks, that's what I thought, just wanted to make sure people weren't picking -1.5 to 1.7 cuz it works better with stock suspension.
Old Nov 19, 2005 | 12:13 PM
  #23
spoiled@21's Avatar
my front camber maxed out at -1.0 with zero toe. I imagine with like a 1/8th toe out you could get a little more. MY01
Old Nov 22, 2005 | 05:32 PM
  #24
Race Miata's Avatar
max possible FRONT camber is not hindered by toe setting. Were you thinking about caster instead of toe?
Old Nov 22, 2005 | 05:45 PM
  #25
Race Miata's Avatar
Even if it was possible to get more than 1.5 camber up front to improve cornering grip, you would lose braking traction on the other hand.
While we are at it, I read on some other thread that talked about loosening and shifting the front subframe to the side with less possible camber in order to maximize it. Although not significant, it works! I used to be able to get only a little under 1.5 camber on the driver front and a bit over 1.5 on the passenger front, with me sitting in the car. When I did my clutch swap, the subframe had to be loosened and lowered so I took the time to shift it to the driver side as much as possible before tightening up. Now I get just a little bit over 1.5 camber on both sides.
Old Nov 22, 2005 | 08:28 PM
  #26
Cone_Killa's Avatar
Well, picked up the car today and the #s look good! With 170 lbs driver:
LF: -1.75 (before -.47)
RF: -1.77 (-.57)
Toe is set to 0 for now, I'll try it at the next autox with the 710s and go from there.
LR: -2.25 (-1.46)
RR: -2.25 (-1.64)
Toe is also 0 in the rear.
The guys at the local shop said they had no problem getting that much camber up front and can probably get -2. I might try that next.
chairmnofthboard
30
Dec 15, 2016 07:39 AM
fallen612
Sep 16, 2009 06:27 PM
BlackJoker
Sep 3, 2005 11:10 AM
honda_s2k
Apr 13, 2004 09:14 PM
FF2Skip
Jul 2, 2003 10:33 AM
