Catch Can Install
Old Jun 26, 2014 | 06:49 AM
iamxpl's Avatar
Clyde! you're alive! , well at the last autocross i filled my catch can twice on a 35 sec course. there was heavy transitions and a right hander that went over a crest. i dumped out half a quart of oil. maybe its also time to either change PCV valve or just clamp the PCV all together.
Old Jun 26, 2014 | 06:56 AM
recnelis's Avatar
Technically, 13.10.E prohibits you from clamping/capping the PCV if you're running Street/Street R or STR (can't alter the PCV system). It would likely be OK with the local STR crowd, but don't run it like that at a national event.
Edit:
13.10.E is what explicitly allows the oil catch cans.
Old Jun 26, 2014 | 05:44 PM
DrivenAP2's Avatar
The easiest way to explain it is, the can is an inline filter, just put the can in the middle of the PCV line, and the breather tube if you want. The breather will allow small amounts of oil through the throttle body that will build up over time, but the system was designed to work as a whole.
If you don't have anything stopping you from breaking the stock system, I would run both lines from the valve cover to a vented can, and cap the intake side.
Old Jun 27, 2014 | 12:00 AM
tbpom1003's Avatar
Originally Posted by iLuveketchup
Don't laugh at the silly strut bar. lol It's there to take up space and it's something to lean on.
i have this setup too. have no problem so far
TangoVTEC
Aug 11, 2011 07:51 AM
dc_s2k
May 25, 2010 08:54 PM
trips2k
May 3, 2010 09:37 PM
sbrodacz
Apr 8, 2009 10:03 AM
BNB
Aug 13, 2007 05:36 AM
