Effects of rear toe-in?
Old Jan 3, 2010 | 02:11 PM
robinson's Avatar
That's not what I'm saying. If you have understeer now, reduce the front sway stiffness. I would not go past the min recommended toe in for the rear.
Do you have more rear camber than front?
Old Jan 3, 2010 | 03:45 PM
SILAP1's Avatar
I agree ^^^^ Less front bar and keep the rear toe
Old Jan 3, 2010 | 04:25 PM
dan_uk's Avatar
yea I was running -3.5 camber rear and maxxed out at -2 front
I am gonna change that to run -2.5 rear and -2 front since I'm running streets next year
Old Jan 4, 2010 | 08:34 AM
TheNick's Avatar
Way too much rear camber. Run your front bar full stiff to maximize the contact patch and grip of the front tires since your front springs are so soft - you are still using those goofy KGMM Progressive rate springs right? When you run too little roll rate in the front of the car - you will increase understeer if you soften it up.
Dial out your rear camber to 2.5 or less. Keep rear toe in to keep the car stable on turn in and corner exit.
Old Jan 4, 2010 | 10:25 AM
dan_uk's Avatar
yea KG/mm springs they work pretty good I think they are so old and knackered they lost the first part of spring
what camber is ideal for RE-11's?
ES2K
Apr 14, 2015 08:41 AM
HH-S2000
Sep 4, 2009 03:46 AM
dan_uk
Nov 17, 2008 02:59 PM
Antonov
Jan 30, 2008 03:26 PM
IIGQ4U
Aug 9, 2006 12:55 AM
