Final drive - Going backwards?
If 4.1 is "optimal", then if you suddenly started cornering at 10% higher speeds, "optimal" gearing would go to 4.1/1.10 = 3.73 to be at the same rpm in corners.
It will totally depend on the track, but in my experience (stock AP1 on R-comps), 4.1 is pretty good for most tracks.
The desire to believe that gearing is always a huge performance improvement is significant in these parts (s2ki)! But in general it will only help acceleration numbers from a dead stop or very low-speed roll. Above that, whether they are an advantage or a DISadvantage depends totally on the speeds you are accelerating from and to.
Originally Posted by Thebob' timestamp='1368083197' post='22530039
What about when you make the shift to R compound tyres? Will the 4.44 be better suited because you should be carrying more speed throughout the track?
The point is that you can't just go to lower (numerically higher) gears and just expect to be faster at a road course or at an autoX as a matter of course. Best gearing depends heavily on the rest of the car's setup and the track or course being run. Shouldn't be at all surprising that if the stock gearing was working well at a track for a given setup, that 4.44's might be slower due to more upshifting and being out of the powerband at critical corner exits.
I'd be personally looking for ways to get more midrange out of the car so that gears don't seem necessary. Back when I had my first I almost pulled the trigger on 4.44s. I'm not in a 06 and have no desire to touch the gears. I'll get far more out of a flashpro and tune with vtec lowered. Not sure if that's an option for you or not. On anyone with a 06+ I'd absolutely go flashpro and tune over gears. If I can get vtec lowered and open up midrange and I can't see wanting the gearing to be any shorter.
