KW V3 Tuning Guide
after testing i ended with bump at 3 and rebound at 9/11 (f/r).
this gives me good soaking at bad road and bearable body roll.
mine are with stock 80 springs (~8.5kg) and i also have eibach sways set to stiff.
body roll eliminates almost completely if i add 1 more click for rebound and it's still quite good on the bad road.
Rob - Billy Johnson helped me set up my first car, he said to always set the shock to FULL STIFF and then back off from there. I found it odd you do the opposite. Does it even really matter? I stuck with the advice Billy gave me, for obvious reasons but figured I would ask.
I think it's because the standard V3 uses the stock top hats which fit the main spring, the Clubsports come with top hats that fit the helper springs.
it looks to me that i use high bumo dumping but middlerange rebound damping.
I think so long as you are on one end of the spectrum (full soft or stiff) before you go to your choice setting, it acts as a "reset" and you're good to go. I don't doubt Rob knows what he's doing by any means, and either method will work fine. (Again, my presumption for the time being.) Your results may vary.
http://robrobinette.com/images/S2000...ort_Manual.pdf
Originally Posted by afzan' timestamp='1349636349' post='22065092
[quote name='Squirtle' timestamp='1349564437' post='22064003']
[/quote]
KW & Billy J set the shocks to full stiff before setting the desired position to confirm the "0" reference. Full stiff is more definite than full soft.
The Penske "Start-up Guide" that I used in my tuning guide is a way to start from scratch and get a good initial setting. Starting with both settings 1 setting from full soft (because KW says not to use full stiff or full soft) will teach you a lot about shock tuning. The start-up procedure is not required because there is so much data out there on setting V3s and Clubsports on S2000s.
very helpful, Rob...Thanks! I think I may be misunderstanding something, and hope you can clarify. The "fine Tuning" section seems at odds with the flow chart floating around car forums (based off Greg Simmons from Penske and found in Staniforth's Competition Car Suspension book. The "+" means stiffer and "-" softer, correct? Here's that flowchart diagram, taken from the Lotus forum, but also linked here somewhere IIRC (I assume increase=stiffer and reduce=softer)
Can you clarify this? It *seems* your understeer suggestion may be at odds with the diagram. What am I missing?
Steve
Steve
