Mounting ballast weight
Old Aug 7, 2013 | 10:41 AM
patinum's Avatar
Default Mounting ballast weight
Apparently I went a little overboard when I was stripping the car. Right now to meet my minimum weight requirement for NASA Time Trials, I need 20Lbs of ballast and a full tank of gas. 20lbs really isn't a lot but I'll probably want to run more depending on my fuel level.
Anyone have any suggestions or creative solutions? Or is the obvious answer (weight lifting plates in the passenger footwell) the right one?
Old Aug 7, 2013 | 10:25 PM
thepoi's Avatar
If I were in your position I'd bolt a suitable steel plate to the frame, under the CG of the car and offset to the passenger side (which is probably right under the passenger seat, I'd guess).
Old Aug 8, 2013 | 07:22 AM
cracknut's Avatar
If I my plans for the SCCA runoffs at Laguna come together I'll be needing to ballast well over 100lbs into the car. Check out the SCCA GGR rules for ballasting. They'll explain how to do it safely.
Old Aug 8, 2013 | 08:11 AM
Forcednduckshn's Avatar
Roger that.
There was a gentleman here selling his AP1 race car (maybe speedengineer?) I forget the name. But he indicated he had a ballast setup similar to that, where ballast could be removed/added easily via being bolted to the underside of the car underneath the passenger side seat area.
Old Aug 8, 2013 | 10:11 AM
rrounds's Avatar
Can you use a four wheel scale and even out the weight on all four corners?
ROD
Old Aug 8, 2013 | 08:49 PM
speedengineer's Avatar
I made these for my TTC setup. The steel tubes are filled with lead, and they weigh 37.5 lbs each, so the 4 of them are 150lbs total. I also had another 60lbs or so bolted in the trunk.
Old Aug 9, 2013 | 04:53 AM
patinum's Avatar
It's probably easier than it looks, but I don't knkow if I can make that on my own. Want to make and sell some to me?
billios996
Sep 12, 2012 06:04 AM
T-Smac
Oct 9, 2011 03:00 PM
sharksfinn
Dec 22, 2009 09:39 AM
russellhq
Aug 1, 2007 12:47 AM
nickrg3
Dec 20, 2005 01:28 AM
