My head is very close to the roll bar
#31
SIRBIKEALOT7, those look like some pretty sketchy mounts! you should be bolting those to the floor directly, and you need a 4x4" plate on the underside of the car to act as a 'washer' to keep the bolts from pulling through the car in an accident. the factory mounting locations are really strong, but with that bent metal welded to the mounts you're giving a lot of room for flex in an accident. You could end up with a seat that is pointing you diagonally towards the driver's side mirror, or worse. I would think about changing the seat mounts, no one wants to crash, but EVERYONE wants to walk away from one. I'd also use high grade bolts to mount to the floor, and you don't need to buy the special seat mounting plates from G-Force or wherever, just go to Lowe's and get some 1/16" (there abouts) thick steel and use that for a washer. Cut it so you can use 1 long rectangle one either side of the mounts and put two holes in it, and round the edges, etc. Account for any non-flat areas under the car, where you're mounting the seat (if I remember correctly the portion of the under-car near the transmission tunnel isn't completely flat and you may need to drill a very short slot to get the plat to fit).
Sorry to hijack.
Sorry to hijack.
#32
The broomstick test is a pretty good indicator on whether you are "ok" on clearance. Some of the pictures look like your head is above your bar when you are leaning forward to avoid it being "on" the bar. Leading me to believe you'd fail the broomstick test which is pretty rudimentary and simple to do at home by placing a broomstick from the top of the bar to the top of the windshield directly above your head....if you touch it fails.
Now as for the seat mounting....i'm 6'3" or 6'4" and weigh in the realm of 250 or so 260, not a small human by any stretch. I drilled the factory mounts out of my car and mounted my seat directly to the floor gave me quite a bit more room. Might not be an option for all, but might be something to look at.
#33
