My homemade alignment string setup
Old May 23, 2015 | 07:06 AM
  #31
Dead Serious's Avatar
Originally Posted by shind3
Thanks for the earlier posts. Good info.
Let's talk about the tolerance stackup. Lots of things to consider here but let's start with the biggest contributor for most. Being able to measure to 1/32nds sounds impressive but it's not that great. Let's say everything is boxed up perfectly and you are measuring the leading and trailing edge of the wheel to within a range of 1/32" or +- 1/64". You are making 4 measurements per axle for toe and worst case scenario you could make all of them wrong by 1/64". That is 1/16" of total measurement error per axle. For a 17" wheel that results in about 0.20 degrees of total toe error using this trig calculator. I believe the factory says that total toe range is about 0.40 degrees so you've eaten up almost half of the entire range.
Obviously, the key to a good alignment is to reduce that per measurement error. Some people are good doing it consistently and looking for the diffused light through the fishing line as the lines on the scale underneath show up. I personally chose to use a Vernier caliper with a dial in inches. I took the same measurement multiple times and found I could generally get the values to within a range of 0.015". That is +- 0.075" times 4 = 0.03" of total measurement error per axle. That is total toe error of 0.10 degrees which is almost twice as good as using a ruler that reads to 1/32nds.
So the moral of this story, ditch the little ruler and use some Vernier calipers. Also, do a 'Gage R&R' on yourself and for your first time, take those same 8 measurements 10 times over. See what kind of measurement range you get. I was within 0.015".
The error in trackwidth between Rob's and Andrew's measurements by comparison is about 1/32" over 94.5" which only results in an error of 0.02 degrees.
Also there are other variables like wheel runout which can be quantified by a dial gauge which wouldn't be a bad idea to do.
Spoken like a Quality Engineer. Your Cpk had better be 1.33 or there'll be hell to pay.
Old May 23, 2015 | 08:03 AM
  #32
shind3's Avatar
Wow, you're absolutely right! My job is to approach every situation from a negative point of view, lol.
Also, I noticed that keeping the strings as far away from the wheels as possible by your measuring device results in a smaller error due to not having the strings exactly at hub height. I was also able to get more repeatable measurements this way. I might even feel confident enough to say I can take a measurement to within 0.01" now. Calipers of course.
For reference, 180 degree rotation of the front tie rod resulted in a change of 0.15 degrees of toe. My precision across two separate days of setting up strings was 0.06 degrees, which I tested on the right rear as I left it untouched between them. I may have gotten slightly better at setting it up so I'll check it a 3rd time to see what I get.
EJ86
Apr 19, 2016 03:10 AM
cosmomiller
May 26, 2014 09:07 AM
Thateguhate
Feb 6, 2014 02:21 PM
2004S2000
May 1, 2007 01:37 PM
