Noisy diff after tracking
Old Mar 18, 2003 | 06:08 PM
Yellow Streak's Avatar
Default Noisy diff after tracking
Is it normal for the diff to be a bit noisier after 2 track events? I am running Redline 75W90 in the rear and I notice that it is a bit noisier at slow speeds under balanced throttle. Should I perhaps consider Redline Shockproof?
-YS
Old Mar 18, 2003 | 06:19 PM
pfb's Avatar
pfb
Redline strongly discouraged me from using shock proof gear oil in a street car. They feel is just doesn't perform as well as their normal gear oil when not at full operating temp.
Great in cars that get the diff hot, and keep it hot, like racecars. Not good for daily drivers.
But to answer your question, I've never heard any diff noise, either with stock Honda gear lube or Mobil 1 75W90.
Old Mar 18, 2003 | 06:42 PM
CG's Avatar
CG
That doesn't sound good. When my diff got to making noise I had to eventually replace it. I drove and autoXed it for about 4 months after the noise started and it was just a little louder when it was replaced. I don't know how long it would have lasted.
I wouldn't run shockproof in the S2000 but I love it in my F2000's gearbox.
Old Mar 19, 2003 | 03:43 AM
Thanks for the info. The car doesn't see much street time at all - about 80% track, 20% street. I am wondering if the 75W90 is thinning or if the rearend is going. I guess I could try Shock Proof for the next track event and see how it does.
-YS
[QUOTE]Originally posted by CG
[B]That doesn't sound good. When my diff got to making noise I had to eventually replace it.
Old Mar 19, 2003 | 07:31 AM
CG's Avatar
CG
Originally posted by Yellow Streak
What was the indicator that yours needed to be replaced?
-YS
It just kept whining or whirring under steady throttle or very light acceleration. It seems like it was easiest to hear in 3rd or 4th gear around 40 to 45mph. It was covered under warranty but Honda made it clear that it would not be covered a second time and they said at that time that ALL differential failures had been due to abuse. In my case they said it was due to the tight turns under power in autoX situations. Their claim was that you could not do tight turns with an LSD without damaging it. I did autoX the car for two years but I never did a single 0
Savvas
Mar 1, 2017 12:11 AM
SCZ4
Feb 11, 2017 01:44 AM
driftintherain
Apr 11, 2009 09:52 PM
moey1188
May 11, 2008 06:50 PM
mwy23
Jul 20, 2005 06:39 AM
