rotor wear
Old 04-07-2007, 06:41 AM
gpw04's Avatar
Default rotor wear
i was HPDEing at lime rock last week using a new set of RacingBrake 2 piece slotted rotors (stock size) with hawk DTC60 (front) HT10 (rear) on V710's. after one day, the rotors wore down through the slots.
i ran DTC70 before without this problem on stoptech oem rotors and i thought DTC60 is less abrasive. racing brake told me that it's likely because the stock size rotors are too small and that they are working on a BBK with science of speed using stock calipers with larger brackets. would a BBK really make that much difference on the s2k, or is my problem related to something else, like bad braking technique, bad calipers, front/rear pad combo, etc.? thanks.
Old 04-07-2007, 07:52 AM
SR71BB's Avatar
You wore out a set of rotors faster than a set of pads? No, the rotors are nfg, in my opinion.
Old 04-07-2007, 08:44 AM
crash's Avatar
that is just not right.
I would be talking to the manufacture of the rotor before I went any further.
there is no way you should wear through rotors before the 1st set of pads.
Old 04-07-2007, 09:32 AM
blackey's Avatar
I get 6-8 races out of rotors before they crack. They aren't even close to wearing through.
Pads last 5-6 days.
Old 04-07-2007, 11:45 AM
mikegarrison's Avatar
I've never worn out a set of OEM rotors. They always fail by cracking. And never in a single event, but I don't seem to get 6-8 from them either (usually).
deepbluejh
10-05-2014 10:34 AM
Keelr
09-26-2007 04:24 AM
-DOZER-
07-05-2007 05:17 PM
JayStyles662
03-16-2007 05:28 PM
Moneeb
06-27-2001 10:11 PM
Quick Reply: rotor wear
