S2000 Aerodynamics
Old Jul 28, 2014 | 09:30 AM
  #131
Slowcrash_101's Avatar
Design constraints, ideally you would want a multi element wing, with the main element as high as possible with multiple slots towards the end plates, and a lower element who's wake is adding to the rear wake of the diffuser. Also adding serrated turning vanes to the diffuser will increase the stall limit and reduce pitch sensitivity.
Old Jul 28, 2014 | 09:51 AM
  #132
thomsbrain's Avatar
Originally Posted by Slowcrash_101
A lot of wings have a neutral center section precisely because of this, by keeping downforce high at the wing tips, and low in the center lowers the tendency for pressure fluctuations across the wing under yaw at the sacrifice of overall downforce.
My impression has been that the "neutral" center section is an attempt to maintain somewhat constant attack angle across the wingspan. The air coming over the roof attacks the wing at a different angle than air flowing along the side of the cabin and the wings are shaped to maintain constant attack relative to incoming airflow. As you increase overall wing angle, a straight wing will stall in the center sections prior to the edges unless it is mounted above cabin height or really far back, both of which are often regulated by rules in competition.
Old Jul 29, 2014 | 11:20 AM
  #133
Clark's Avatar
"both of which are often regulated by rules in competition. "
That was my main question. As just an HPDE junkie I get to 'run what I brung'. I know most series people in this forum participate in tend to limit wings height and width (or else you jump to a new and undesirable class). I don't recall reading much though on rules regarding how far back the wing can be mounted.
boyguan
Jan 12, 2014 10:31 PM
myhui
Nov 18, 2013 06:39 PM
Bryan@BerkTechnology.com
Mar 14, 2008 05:49 PM
LubedKoala
May 30, 2005 04:25 PM
