Spec S2k series discussion thread
Originally Posted by KrazyKarim,Jun 12 2006, 03:17 PM
I'm not too keen on thei dea of limiting ap2s to 16in wheels yet. We already know what an ap1 with kws and 16in ra1s can do but the ap2 with 16in wheels is uncharted territory. I don't think there is anyone with an ap2 who has put ap1 wheels on yet. So no one knows how the car would react or how it handles on that specific setup.
That is all,
Karim
That is all,
Karim
Originally Posted by mikegarrison,Jun 12 2006, 04:41 PM
Frankly, if you are going to spec a particular suspension, I don't see any reason why it can't be the OEM suspension. That would be cheapest. And it's silly to say that it's not "safe" with R-compounds.
I have a feeling that the impression of it not being safe was related to the bumpsteer issue rather than the damping and spring rates.
The suspension gets really twitchy under that kind of load. The BSK makes it safer, but only in one respect
Originally Posted by drewchie,Jun 12 2006, 05:04 PM
Have you driven a stock S2k on r-comps at the limit?
I did put in the bumpsteer kit before I started using the RA1s.
As for "at the limit", well I drive close to my limit. I won't presume to say that it is necessarily the car's limit.
I vote for stock suspension also. All we want to do is equalize the cars so driver is the variable, but also make it trackworthy. So brake pads/fluid and tires are the only needed changes, with only wheels+tires requiring a spec. The only disparity then becomes 2.2 vs. 2.0 and bumpsteer, and that's all we should try to solve. Few other mods that don't have a meaningful impact on laptimes can be allowed as discussed by others earlier. It needs to be simple and cheap.
Originally Posted by mikegarrison,Jun 12 2006, 05:10 PM
I haven't driven an S2000 on r-comps with anything OTHER than the stock coilovers. I kind of giggle when you guys say that it can't be done.
I've also driven on the KWs and the difference is huge!!! Instead of a scary twitchy ride, it's flat and smooth.
If I were to name a single factor that is most detrimental in my current setup, it would have to be the suspension. Not only does a good set of coilovers help, but they also inspire much more confidence and are frankly a lot more fun. Yes $1800 bucks is a lot, but we thought long and hard on this one.
That said... it's still not written in stone.
As for the person who suggested the new Tein setup... yes, I too have heard very good things, but that would add at least another $500 to the price tag. For now, I think the KWs are expensive enough.
Again, it gets back to what you are really trying to do. It sounds like the real goal is to get the most interest, not to make the fastest car or the cheapest car.
What you have to decide is if a particular rule will add or detract interest. For instance, the coilovers: if it is more fun to drive the car with the coilovers, perhaps more people will want to participate even though it costs extra money. That's the real metric you need to be looking at.
If you come up with a set of rules that works for this spec series but nothing else (doesn't make a good street car, limits what people can play around with as a HPDE car, doesn't work as a race car) then you are unlikely to draw serious interest.
If you come up with a set of rules that is compatible with street use, then you may get a lot more interest because people won't have to have a "SV Spec S2000" car that they can't use for anything else.
Otherwise I think you will end up with basically the series you already have.
Originally Posted by twohoos,Jun 12 2006, 02:53 PM
Minor nit:
If BSK is permitted, it should be permitted for AP1 and AP2. If we claim that it does nothing for an AP2, then clearly it should be allowed since it's not a performance aid. If OTOH it would improve the AP2, then by definition it's just bringing the AP2 to the same level as an AP1 w/ BSK, so again it should clearly be allowed.
