Speedventures classing input thread - #72
Old Apr 23, 2003 | 04:33 PM
  #191
fluxen's Avatar
Ok, I've updated the Challenge Series Points. For those for whom I'm not sure of the classing, I guessed. It may not be scientific, but points are updated, errors though there may be. Let me know if I've got you classed wrong.
Thanks, all!
Old Apr 24, 2003 | 03:57 PM
  #192
desert tortoise's Avatar
Reverend, Fluxen
Rev, I suppose you found out that Spring Mt. is not $600/weekend? Also, you asked about signing up for one day and then getting the second at the two day rate. Yes, you can do that.
Somebody needs to teach Fluxen how to create new "Folders" in Outlook and then "File" things into the "Folders" so that he can "Find" things more easily and not treat us all like children because he doesn't know how to use a "Computer".
Who else is sick of being treated like a child?
dt
Old Apr 24, 2003 | 04:00 PM
  #193
Strike's Avatar
Thanks for updating the points. However, I've decided I liked it a lot more when I was tied for 1st in my class with 0 points than now when I'm not even in contention
Old Apr 24, 2003 | 04:19 PM
  #194
krazik's Avatar
Administrator
well Aaron and I aren't in Mod anymore
Old May 28, 2003 | 09:32 AM
  #195
Prolene's Avatar
I estimate I will still be in mod, barely, if I use stock ecu, cat, nonspec tires, and stay away from front sway bar and 4.44 gears. I think 205/255 17" SO2-As designed for Porsche might allow the car to remain on par.
Old May 29, 2003 | 01:30 PM
  #196
Asura's Avatar
[QUOTE]Originally posted by Prolene
[B]I estimate I will still be in mod, barely, if I use stock ecu, cat, nonspec tires, and stay away from front sway bar and 4.44 gears.
Old May 29, 2003 | 03:58 PM
  #197
Prolene's Avatar
Originally posted by Asura
Are you considering BFG KD's in the same size or 225/255?
I just checked the specs for KDs and like what I see. I'd probably try the 205/255 since I have stock '00 bars. Thanks. When the Kumhos on the CE28Ns are used, and I use up the AVSis awaiting the 17's, I might give the KDs a try.
Old Jun 8, 2003 | 09:09 PM
  #198
CMiS2K's Avatar
does anyone have a picture of the speed sensative Wing?
Old Jun 25, 2003 | 12:38 PM
  #199
Boy, Look at that oil blowoff on that hard right hander!! That's smokin' in true S2000 style.
I don't think the wing is speed sensitive, it's manually controlled, but there are pictures all over www.nsx-files.com, and probably on s2ki as well.
Bitterman
Old Jun 25, 2003 | 12:50 PM
  #200
slick rick's Avatar
whaddaya doin lurking around here?
