Splitter APR vs wood
Really depends on what your needs are. If you have a small wing you may not need a crazy diffuser so you could get away with APR. Making your own takes more time and some more skill but it does let you customize it to your needs. Also when you make your own you can make a template so that when you end up wrecking it you can easily and cheaply remake another one. Use birch, its light and strong.
I would want something thing that I could stand on....but if I bounce on it would break away.
Devsport mounts and any turnbuckle type rods will bend or rip out of the splitter long before there is any threat to the chassis. I made my splitter out of alumalite. More expensive and a lot harder to find than wood, but lighter, thinner, and better fire resistance.
Doing it over, I'd buy (or build) quick release splitter mounts up front so I could get away with not having to remove the front bumper every time I needed to pull the splitter.
https://racebredcomponents.com/produ...litter-bracket
I would probably find conical washers for that (like the below image), rather than straight ones.
My dad has the devsport and thinks if you spot welded the nuts on the bottom of the mount, you could remove it from below with just a wrench.
shaolin
Oct 27, 2005 12:01 PM
