STR Prep - Suspension and Alignment
Old May 9, 2012 | 05:09 AM
  #291
glagola1's Avatar
There is bumpsteer in the front but I don't know of anyone who has measured it. I mean, it probably has less effect on the dynamics of the car than the rear considering the front wheels are always changing directions.
Old May 9, 2012 | 11:35 AM
  #292
Topplayer's Avatar
after installing a front swaybar like the gendron do you need to get an alignment?
Old May 9, 2012 | 02:23 PM
  #293
ebdavis's Avatar
No
Old May 9, 2012 | 02:59 PM
  #294
legend4life's Avatar
If it's connected while setting your ride heights or alignment, it can add significant preload and throw things off.
Old Sep 29, 2012 | 10:46 AM
  #295
762's Avatar
762
Just figured I should post on here to get this topic back up now that discussion over alignment and front camber has come back to the forefront.
Who is now running more than -3 degrees up front? and what camber solution are you using to get there?
Currently I am on the S1 J's joint and I am maxed out at -3. So it looks like I may have to go for the S2 joint unless someone has a better solution.
Old Sep 29, 2012 | 11:14 AM
  #296
IntegraR0064's Avatar
The S2 will easily do it. I just set mine to 4 degrees no problem with the S2 joints. I've been running 3.2 in front (although I guess it slipped back down to 3.0), I think I'm going to try a little higher and see how it goes.
Old Sep 29, 2012 | 11:21 AM
  #297
pinkertonpunk's Avatar
I have offset delrin upper control arm bushings and when they were new I could get around -3.1 although I've never run more than -2.8. That is where I have it set now.
Old Sep 29, 2012 | 03:19 PM
  #298
mLeach's Avatar
It also depends on your ride height.
Old Sep 29, 2012 | 03:28 PM
  #299
Random1's Avatar
Running the SPC camber joint at -3.1 deg up front, running about -2.7 in the rear.
I have been running like this since July and have about 4-5k miles with no issues on the SPC joints. Drover nervously all the way to Lincoln and back expecting something to give, but all is well. The balls felt nice and tight when I pulled my shocks off last weekend.
Old Sep 29, 2012 | 05:06 PM
  #300
oinojo's Avatar
