View Poll Results: What front sway bar do you use?
Gendron 1.25" hollow
16.57%
Gendron 1.375" hollow
8.84%
Ankeny single blade
0.55%
Ankeny dual blade
7.73%
Comptech Adjustable V2
7.18%
Saner
19.34%
Other
13.26%
Eibach
20.44%
Standard Gendron
6.08%
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
Old Feb 12, 2012 | 05:54 AM
  #221
robrob's Avatar
What years of Miata front sway bars fit the S2000 in the rear? I searched and couldn't find an answer. Thanks in advance.
Rob
Old Feb 12, 2012 | 06:08 AM
  #222
josh7owens's Avatar
06 base, non hardtop
Old Feb 12, 2012 | 06:14 AM
  #223
oinojo's Avatar
06 and newer. I run a modified hardtop with a stiffer hole. Works great!
Old Feb 12, 2012 | 06:27 AM
  #224
robrob's Avatar
Cool, thanks guys.
I talked to Mike Collins, the head of Meathead Racing at Summit Point and he has at least one on hand. We're negotiating price right now. He may have more if anyone in the Mid-Atlantic area wants one.
Old Feb 12, 2012 | 01:58 PM
  #225
jeffjanzen's Avatar
Originally Posted by Forcednduckshn
Originally Posted by legend4life' timestamp='1328860901' post='21401515
[quote name='jeffjanzen' timestamp='1328546424' post='21388089']
[quote name='rrthorne8' timestamp='1328501897' post='21386801']
problems with rubbing.
gendron bar with oem mount. arms rub steering boot and i am now replacing steering boots on both sides.
Was looking to order new bearing mounts from Bill, but now i am hearing the mounts rub too?
any solutions, anyone running bar and not having any problems?
I made 1/2" aluminum spacers to drop my OEM mounts down (they sit between the frame rails and T-brackets). Just pick up some 1/2" x 2" aluminum bar stock from a local metal shop, drill some holes, buy longer bolts, and for about $10 your boots will be safe. Someone is selling them on here now, but they're easy enough to make for a lot cheaper.
BB mounts are nice, but they add almost 5lbs. to the nose (just a guess - has anyone weighed them?). I probably wouldn't do it unless I needed the extra stiffness, but I guess it could be worthwhile if you want to eliminate bushing compliance from your roll stiffness equation.
So the mounts are mainly for extra stiffness? ie would adjusting the bar stiffer give a similar effect?
[/quote]
The major reason for the BB mounts was because of the mushrooming effect that was occuring on the poly-bushing/thin steel mounts that were previously used in conjunction with the monster bar. I went through a couple of sets of mounts myself. The mounts would "add stiffness" by eliminating any slop that would get worse over time in the mounts, though it really isn't effecting the "stiffness" of the sway bar. The bar itself functions (or is intended to function) by resisting the movement of the control arm in torsion/twisting only. When you have slop in the mounts, the bar is allowed to move both in the axial direction and radial direction. That creates alot of variation in the amount loading that actually gets transmitted to each wheel. The spherical bearing setup eliminates any slop and lets the bar work in torsion only.
Nick
[/quote]
How common is the mushrooming problem? I've never experienced it. The only issue I had was with the shitty mounts flexing over time and eventually breaking. Since switching back to OEM mounts I've had no issues and the bushings are staying exactly where they ought to. Guess that's why I assumed the only benefit to BB mounts was the elimination of compliance.
Old Feb 12, 2012 | 06:21 PM
  #226
Forcednduckshn's Avatar
Originally Posted by jeffjanzen
Originally Posted by Forcednduckshn' timestamp='1328900024' post='21402844
[quote name='legend4life' timestamp='1328860901' post='21401515']
[/quote]
Nick
[/quote]
[/quote]
You're just not driving it hard enough.
Were talking about the same thing Jeff. The standard issue mounts flex, bow out "or "mushroom out" as I like to call it and allow for a ton of wobbling. It's common enough, but your mileage may vary... Both sets of my mounts degraded over time in the same fashion. The price you pay for a ridiculously big swaybar? Guess so...
It's possible to run OEM mounts? How does the bar fit in them?
Old Feb 13, 2012 | 06:33 AM
  #227
sirbunz's Avatar
Yes, simply bolt them on over the bushing. I carry a pair as backup. Both of Jeff's mounts broke at the spring Lincoln Tour. He used the OEMs to replace the standard Gendron mounts.
-Marc
Old Feb 13, 2012 | 11:28 AM
  #228
-Marc
Ahh, good to know. They always looked too small to fit the big gendron bar, but I never tried. I'll keep the OEM mounts as a backup! (though those BB mounts aren't going anywhere)
Old Feb 13, 2012 | 01:00 PM
  #229
daverx7's Avatar
I just got my bearing mounts for my front bar and the new Gendron rear sway bar installed this weekend. I can't wait to hit some curves to see where I need to adjust my dampers. It's getting soooo close to being ready. Just the EMU and tune is left... then time to play!
BTW, the rear bar mount holes did not line up with my 2002 and had to drill out the holes to make it work. I know I'm one of the original first 5, so I expected some tweaks. Anyone else have this issue? However, once we got through that, it really looks like a top quality mod.
-Dave
Old Feb 21, 2012 | 12:03 PM
  #230
imstimpy's Avatar
I'm joining the ranks of the smaller rear bar folk! I just had a lengthy conversation with Mr Gendron and it took me in a different direction than I expected.
I originally intended to order the Monster Bar as an upgrade from my 1.25"x0.25". Since I'm currently running my bar at 6/6, I wanted to get the 1.375"x0.25" bar so I could set it at 3 or 4 (roughly equal to my current bar) and have room to go softer or stiffer (mostly stiffer). My concern has always been overloading the front tires, though, and Bill expressed great success with softening the rear from this point.
I've been successfully running the MY06 rear bar now for two years. I didn't like the feel of the car without the rear bar and have been skeptical that the MX-5 bar was enough. I went with Gendron's 1"x0.095" rear kit instead (ouch!). This new rear bar should give me an adjustment range from a touch stiffer than the MX-5 bar to a touch softer than the MY06 bar.
Based upon all the photos I've seen, my car rolls a lot, even with the relatively stiff setup I run, and I've been hesitant to soften it up. At the same time I'm excited to try a softer rear to see if I can throttle through more of the corner.
