View Poll Results: What front sway bar do you use?
Gendron 1.25" hollow
16.57%
Gendron 1.375" hollow
8.84%
Ankeny single blade
0.55%
Ankeny dual blade
7.73%
Comptech Adjustable V2
7.18%
Saner
19.34%
Other
13.26%
Eibach
20.44%
Standard Gendron
6.08%
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
Old Feb 8, 2012 | 07:27 PM
  #201
josh7owens's Avatar
Bill said my .095 ball bearing bar will be shipped out this week sometime. I'll weight everything once it comes in so we have a exact number. Dave already has his but hasn't said anything about it nor has anyone else that ordered one? stay tuned.
Old Feb 9, 2012 | 05:17 AM
  #202
glagola1's Avatar
I ordered one but after trying the AP2 bar on my car, I felt that it was already at the point where I have just a touch too much understeer, even with zero rear toe and before I installed the diff. I canceled my order.
Old Feb 9, 2012 | 11:01 PM
  #203
legend4life's Avatar
Originally Posted by jeffjanzen
Originally Posted by rrthorne8' timestamp='1328501897' post='21386801
problems with rubbing.
gendron bar with oem mount. arms rub steering boot and i am now replacing steering boots on both sides.
Was looking to order new bearing mounts from Bill, but now i am hearing the mounts rub too?
any solutions, anyone running bar and not having any problems?
I made 1/2" aluminum spacers to drop my OEM mounts down (they sit between the frame rails and T-brackets). Just pick up some 1/2" x 2" aluminum bar stock from a local metal shop, drill some holes, buy longer bolts, and for about $10 your boots will be safe. Someone is selling them on here now, but they're easy enough to make for a lot cheaper.
BB mounts are nice, but they add almost 5lbs. to the nose (just a guess - has anyone weighed them?). I probably wouldn't do it unless I needed the extra stiffness, but I guess it could be worthwhile if you want to eliminate bushing compliance from your roll stiffness equation.
So the mounts are mainly for extra stiffness? ie would adjusting the bar stiffer give a similar effect?
Old Feb 9, 2012 | 11:17 PM
  #204
762's Avatar
762
Hmm I wonder if this is because of the two way diff's character under decel. Most the people running the 1.5 OSG still seemed to want the softer than AP2 rear bar.
Bench racing is fun, it seems to have picked up over the last week.
Old Feb 10, 2012 | 05:05 AM
  #205
glagola1's Avatar
Well, the push was there before the diff. It has not become worse with the diff. Besides, who really knows if it's a 2 way diff any how. It could be a 1.85 way. I tend to run more rear roll stiffness than most.
Old Feb 10, 2012 | 07:06 AM
  #206
It seems strange that with more rear roll stiffness, and even 0 toe, you still experience more push compared to most who run less rear roll stiffness and more toe in.
Any thoughts as to why?
Old Feb 10, 2012 | 07:19 AM
  #207
glagola1's Avatar
Everybody drives differently. I'm coming from the FWD world where you stood the car on it's nose going into corners and then you applied the throttle to get the rear to stick. I'm experiencing a long long learning curve while adapting to the RWD thing. I still drive on the front wheels a bit although I'm getting better at initiating the turn and then completing it with the gas. The zero toe thing has really helped in that regard. The car rotates in a nice controlled manner on exit vs. making the car push. I think that's what too much rear toe in does.
Anyway, yeah, I think I just may prefer more front grip than most people.
Old Feb 10, 2012 | 07:45 AM
  #208
Random1's Avatar
So if you are at zero static toe then you likelty experience toe out under extension, like under heavy braking. You would also have the inside wheel toeing out in turns which intuitively would add stability. Does that make sense?
Thanks for adding your driving style comment. Even though it is mentioned now and then I don t think many people get that part. Setup can be so peculiar that some people cannot drive another persons setup if it is extreme. There was a guy name Josh Sorter years ago that had so much rear toe out on his Subaru that most that tried out the car would spin it. He was a multi time solo national champion and moved onto road racing.
Old Feb 10, 2012 | 09:53 AM
  #209
Forcednduckshn's Avatar
Originally Posted by legend4life
Originally Posted by jeffjanzen' timestamp='1328546424' post='21388089
[quote name='rrthorne8' timestamp='1328501897' post='21386801']
[/quote]
The major reason for the BB mounts was because of the mushrooming effect that was occuring on the poly-bushing/thin steel mounts that were previously used in conjunction with the monster bar. I went through a couple of sets of mounts myself. The mounts would "add stiffness" by eliminating any slop that would get worse over time in the mounts, though it really isn't effecting the "stiffness" of the sway bar. The bar itself functions (or is intended to function) by resisting the movement of the control arm in torsion/twisting only. When you have slop in the mounts, the bar is allowed to move both in the axial direction and radial direction. That creates alot of variation in the amount loading that actually gets transmitted to each wheel. The spherical bearing setup eliminates any slop and lets the bar work in torsion only.
Nick
Old Feb 10, 2012 | 10:45 AM
  #210
Random1's Avatar
That slop would translate to an effective delay in transition settlling as well.
