View Poll Results: What front sway bar do you use?
Gendron 1.25" hollow
16.57%
Gendron 1.375" hollow
8.84%
Ankeny single blade
0.55%
Ankeny dual blade
7.73%
Comptech Adjustable V2
7.18%
Saner
19.34%
Other
13.26%
Eibach
20.44%
Standard Gendron
6.08%
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
Old Oct 21, 2011 | 10:08 AM
  #31
mLeach's Avatar
oem.
Old Oct 21, 2011 | 10:50 AM
  #32
josh7owens's Avatar
I'm 98% sure I'm using miata bushings and miata C-mounts and just using s2000 bolts. Oem C-mount wouldn't fit the miata bushing. Maybe they do?
I used...
Miata bar
Miata bushings
Miata C-mounts
S2K bolts
S2K endlinks
Old Oct 21, 2011 | 11:02 AM
  #33
mLeach's Avatar
ditto.
Old Oct 21, 2011 | 11:40 AM
  #34
H22A_CD5's Avatar
Originally Posted by mLeach
oem.
Originally Posted by josh7owens
I used...
Miata bar
Miata bushings
Miata C-mounts
S2K bolts
S2K endlinks
Thanks, this will probably be in my near future.
Old Oct 21, 2011 | 11:51 AM
  #35
Conedodger's Avatar
I don't know anything about the Eibach bar. if it's 32mm thats 1.25" so the numbers should be around the saner or the 1.25" gendrons depending if it's hollow or not.
The Eibach bar is hollow. It is 32mm OD. I have not seen any information on wall thickness.
Old Oct 21, 2011 | 12:10 PM
  #36
berny2435's Avatar
eibach swaybars
ref https://www.s2ki.com/s2000/topic/822...y-bars-review/
S2000 Eibach Sway Bar rates:
Front: 32mm Adjustable (HOLLOW)
Pos.1 - 65 N/mm (368lbs/in)
Pos.2 - 73 N/mm (416lbs/in)
Weight - 4.8kg (10.6lbs.)
Rear: 29mm Adjustable (HOLLOW)
Pos.1 - 90 N/mm (515lbs/in)
Pos.2 - 106 N/mm (605lbs/in)
Weight - 4.9kg (10.8lbs.)
OEM S2000 Sway Bar Information:
AP1 100 series-
Front sway bar part number: 51300-S2A-003
28.2mm (HOLLOW) with a 5mm Sidewall
Rating at 61.6N/mm
Rear sway bar part number: 52300-S2A-013
27.2mm (HOLLOW) with a 5.3mm Sidewall
Rating at 73N/mm
AP1 110 Series-
51300-S2A-J01
27.2mm (HOLLOW) with a 5mm Sidewall
Rating at 53.6N/mm
Rating at 73N/mm
AP2 120 Series-
Front sway bar part number: 51300-S2A-013
26.5mm (HOLLOW) with a 4.5mm Sidewall
Rating at 46.6N/mm
Rear sway bar part number: 52300-S2A-J01
27.2mm (HOLLOW) with a 4.5mm Sidewall
Rating at 67.6N/mm
130 Series-
Rating at 46.6N/mm
Rear Sway bar part number:
Do not have
25.2mm (HOLLOW) with a 4.5mm Sidewall
Rating at 51.6N/mm
Old Nov 21, 2011 | 06:59 AM
  #37
Angrywankel's Avatar
How do I know if my AP2 is 120 or 130 series? Searched a bit, couldn't find an answer.
Old Nov 21, 2011 | 10:43 AM
  #38
josh7owens's Avatar
Does it matter? Are you planning on running a oem bar?
Old Nov 21, 2011 | 12:32 PM
  #39
oinojo's Avatar
Because he wants to know? I believe 06-07 is 130 series. My 2006 has the 25.2mm rear bar.
Old Nov 21, 2011 | 03:25 PM
  #40
TTMartin's Avatar
Here's a better reference for OEM springs and sway bars
Characterization of the Honda S2000 Original, Equipment Suspension Springs, John McCanless (s2ki.com user name: twohoos)
edit: all AP2 rear bars were 311 ft/lbs.
