View Poll Results: What front sway bar do you use?
Voters: 181. You may not vote on this poll
STR Prep - Sway Bars
wow! That's a serious write-up! Good to know the rear bar rate is 311 finally.
The stock bar information I posted above is actually copied from another thread. I threw it in quotes just so it's a little more obvious it's not information dirived by myself.
edit: Just ordered a used NC front bar from Flying Miata. just over $80 shipped.
http://www.flyinmiata.com/salvage/index
I got the only one they had in stock.
Reason I asked is my car is pretty oversteery. I heard some people run with no bar. Figured I'd try a smaller rear bar (miata). Needed to know what stock was so i can try and figure out what % softer I would be looking at.
If you mod and dont keep track of the numbers, you're shooting blind.
I'm trying to decide between the Gendron 1.25" solid and 1.25" / 0.25" hollow bar. I'm running 850/700 (correction here, not 750) spring rates on Moton Club Sports. Bill Gendron told me the solid would work fine and said for the spring rates that I'm running that even the 1.25" / 0.25" hollow bar would be fine. I'm still tending towards the solid bar in case I ever need to bump it up to the 900'ish lbs rate but he was mentioning that the 1.375" hollow bar was really made for the guys in AP1/AP2s in BS that REALLY needed all the front bar they can get to compensate for the low front stock spring rates. The poll on the first page seems to be confirming the choice on the 1.25" hollow bar over the 1.25" solid bar unless not everyone has voted yet. Thoughts?
I'm trying to decide between the Gendron 1.25" solid and 1.25" / 0.25" hollow bar. I'm running 850/750 spring rates on Moton Club Sports. Bill Gendron told me the solid would work fine and said for the spring rates that I'm running that even the 1.25" / 0.25" hollow bar would be fine.
In STR, I run the hollow, because it is significantly lighter than the solid. You could use the solid bar as a curling bar. You can run spring rates to get a good balance, and you should have no issues tuning the rest with the range of the regular hollow bar.
I don't have any body roll/rubbing uses using it. I have 800#f/650#r springs, "b stock" koni's, 255 RS3's, no rear sway bar, and the normal rolled fender inner lip.
Also, mine currently understeers a lot. I'd like to go 700 or 750# rear springs, and maybe soften the front if needed. I don't think I'd ever even want the stiffness of the solid bar up front unless I still had a beefy rear bar on.
If I didn't have a solid bar already I would prolly go with the hollow bar since it's lighter and set it at full stiff. Then tune the rest of the car.
I'll also add the second place ap1 at nationals ran a hollow bar on full stiff.
Just make sure you buy the ball bearing mounts.
Please elaborate. Is it a performance and/or reliability thing?
Thanks,
-Dave
