Track Car Maintenance
Fuel filter as in sock pickup thingy?
Quick flush is if I am heading to a demanding track on brakes. ACS on the west coast. About 1/2 bottle.
Every time I change pads I bleed a little bit prior to pushing the piston in for the new pads. Gets the fluid out that could have moisture or has seen the most heat. I'd rather bleed that out than push it back into the system.
Originally Posted by 8kGoodENuff' timestamp='1473996262' post='24063109
In reference to the brake fluid, when some people said "full flush" and "quick flush" or "quick bleed", what are these quick flushes or bleeds? Emptying the fluid reservoir and refilling?
Thanks.
Thanks.
Thanks for sharing the little bit about bleeding a little bit of fluid when you push the piston back into the caliper... going to have to try that next time.
Just so you don't feel like you're being ignored Andre.
https://www.s2ki.com/s2000/topic/115...-x-track-days/
freq
May 14, 2017 11:06 AM
