2.2L Engine swap
Originally Posted by S2KEvolution,May 21 2005, 11:09 AM
just left honda with my 00 ecu
lovin' it
lovin' it
Originally Posted by 04RioS2k,May 21 2005, 01:14 PM
hmmm so you telling me that a 00-03 ecu would work on the 04-05 car and it would let me rev up to 9k no problem?
you have to take the car to honda to get the immobilzer keys reprogrammed.
I just got mine done today for free
I got the hook up here
Originally Posted by 03exlcoupe,May 21 2005, 02:17 PM
So i take it the redline warning does not come on at 8000rpm either with this swap?
Originally Posted by 04RioS2k, Posted on May 21 2005, 02:01 PM
interesting, and thanks for the quick response.....hey also how much did the ecu cost you? and when you mean getting the key reprogrammed do you mean you had to get another key made for the new ecu?
also you will need the VIN from the other ECU.
Originally Posted by S2KEvolution,May 21 2005, 06:50 PM
nope... it's just the 2000 ecu and a 9000 redline.
no problem. the ecu was $150. well your key has an immobilizer in it, which keeps it from cranking with a different ecu. I'll save all the technical jargan and just say... bring your keys to the dealer along with your new ecu and get it programmed. They reprogram your immobilizers to work the other ECU.
I'm curious how that works. Sounds like a cool mod though, would be interested to see a dyno comparing the MY04 ECU in a MY04 car to a MY00 or MY01 ECU in a MY04 car.
Originally Posted by billman250,Mar 27 2005, 03:13 AM
Car is doing well at 9k.
04 ecu made 200 rwhp.
01 ecu made 215 rwhp, so we will run this for a while.
Car has a couple thousand miles, and pulls amazingly.
How you like them apples
Been a while since I've called you. Glad to see this thread has been updated. I got a couple issues you may be able to resolve.
1. Why did the 04 dyno such low numbers. I've been seeing quite a bit of 04's dynoing at 210, 215, and over stock. (are you guys using an unpopular dyno or something)
2. I'm leary about the 01 ECU, something about it makes me feel dirty. Is it really safe, have you guys been monitoring A/F ratios and such. I think the added 0.2L is just too big for a 2.0L ECU fuel regulation. Would running an AEM EMS be superior.
Ryan Brown.
Originally Posted by LiQiCE,May 21 2005, 05:04 PM
So did you have to replace the dash cluster (ie. the Digital LCD which shows your rpms, and speed)? ... If not, what happens when you rev over 8200rpms?
s2kevolution,
what are the a/f ratios like? any more info you can provide would be great. i don't care about revin to 9k, i just want 8.5-8.6k where the 2.2l is still making good power. where did you get the ecu?
tks
tks
