2.2L Engine swap
Originally Posted by reds2,May 21 2005, 11:49 PM
This is funny. '00-'01 owners want the '02-'03 ecu because it runs leaner. Now '04 owners want the '00-'01 ecu because it runs richer.
Maybe, since these people are taking the 2.2's into rpm ranges that Honda obviously didn't intend for the engine to go, even if it is physically capable of doing so, they're being on the conservative side from a fuel mixture point of view?
All of the reports I've read on this forum from those who have modified the 2.2's and are taking them to 9000 rpm's have been that the engine is holding up fine. That's good to hear but I think it's still too early to tell what the long term effects on the engine are going to be with respect to it's overall reliability.
Just a thought!
Drive Safe,
Steve R.
- Steve R.I'd be a bit wary about the long term effects of running the 2.2L motor, with its longer stroke, regularly up to 9k. Time will tell. I DO, however, commend those folks that enjoy testing the engineering boundaries (ya'll know who you are!)....and, if past Honda engineering is any indicator, it's quite likely that this mod (00-01 ecu) will ultimately prove to work well. I work for a company where it's common to "over-engineer" by at least 20%.
Someone already posted that they were interested in running the motor to the 8.5 - 8.6k range. I'd be very interested in this too because most of the dynos I've seen on the 2.2L show that the motor is still on an upward ramp in terms of producing more horsepower.
And, paying $150 for this kind of mod is a bargain.
This is going to be a VERY interesting topic to follow...
Dan
Now that we know the 2.2L engine can momentarily rev safely to 9K, does that mean that people who ruined their engines by over-revving, with a red-line 3rd to 2nd down-shift, exceeded 9k RPM ... or is there some other aspect of over-revving from a bad down-shift that makes the same RPM worse than RPM generated by the motor?
I apologize in advance if this is a stupid question.
Thank you.
Thank you.
Mis-shifting (ie doing a "money" shift from 3rd into 2nd when you meant to go 4th) causes a mechanical over-rev for the motor. It can cause the motor to significantly exceed the 9k red line. The primary area of concern after doing this is floating the valves and 1. causing the piston to come into contact with an open valve (very bad) or 2. causing extreme stress on the valve retainers. The second problem may not manifest itself immediately. The over-rev could happen and, a month later, in normal driving, the valve could drop into the cylinder.
As I understand the 2.2L motor running to 9k, it's an issue of the longer stroke on the motor and the forces acting on the cylinder walls from the pistons. With higher RPM, comes more heat, so I think it's safe to say there are *many* other forces at play too.
[QUOTE=Roadster_1,May 22 2005, 09:21 AM] As I understand the 2.2L motor running to 9k, it's an issue of the longer stroke on the motor and the forces acting on the cylinder walls from the pistons.
Originally Posted by 03exlcoupe,May 21 2005, 10:04 PM
s2kevolution,
what are the a/f ratios like? any more info you can provide would be great. i don't care about revin to 9k, i just want 8.5-8.6k where the 2.2l is still making good power. where did you get the ecu?
tks
tks
I got the ECU from a local member on here.
Originally Posted by dyhppy,May 21 2005, 07:33 PM
can you please do a quick recap? all you did was swap the 04 ecu with a pre 04 ecu and take care of the keys, then it all works fine? driving impressions?
thank you
thank you
1) buy the ecu
2) go to honda with the ecu
3) leave your 04 ecu in
4) Honda will hook up the OBD2 scan tool and pull all the required information from your 04 ecu
5) Honda will look up the password for your 04 ecu
6) after all the info is pulled from the 04 ecu, they have the leave the tool plugged in and you swap out the ecu.
7) after the new ecu is installed, Honda will program all the keys that you want to work with that ecu. (I left valet key @ home so it will still work with my old ecu.)
8) that's pretty much it.
I don't know how much Honda will charge you to do this. mine was free since I know the service manager. I talked to another fellow member on here that's a tech and he said it all depends on how much they want to charge you. even though it takes all of 15 minutes to do everything... the charges can be anywhere from $40-100. my friend that's the service manager said that for any other customer, they would have charged $41.95 plus tax.
hope this helps
