4.44 final gear vs. 4.77
I WOULD NOT HAVE THE DEALER DO THIS.
This guys haev no clue on whats going with this upgrade. Aytime they change a rear end, they get a complete one from japan and install it that way.
Go to a local speed shop that has dealt with rear ends in the past, you will have far more luck with them. a local guy said he would charge me 300 for install and calibration.
i'll probably go to 4.77 from 4.44's . i plan on running oversize tire in rear that have greater outside diam., 25.1-25.9in, therfore i'll lose torque multiplication. also this will allow me to easily change final drive by swapping wheels for different tracks or applications.
so if you are worried that 4.77 is too much, you can easily reduce it with larger tire diameter, and there are desirable tire widths that can be only had in the larger diam./larger aspect ratio.
anyone who is not happy with 4.77 gears, we can swap or you can make me a deal i can't refuse.
Okay, so I won't be taking this to my dealer
$300 for install isn't too bad, I can't wait to get this mod working. Has everyone that has completed this upgraded recalibrated their speedo?
a stock s2k usually traps the 1/4 in about 155-160kmh right? thats means u still have to shift into 4th gear and be there for quiteawhile.....
i think the best gear for 1/4 would be one that crosses the 1/4 line pretty much near redline...
(ie same no of shift as stock)
been quite reasonable except for the business about improving drag strip times accordingly by % gear reduction.
Originally posted by ItalianBucwheat
Well Thanks for making me look stupid.
I would be interested in a group buy. After reading this thread I think I am leaning towards the 4.77, but I'm not sure. XVIPER what do you think about your 4.44's? Is there any part of you that wishes you went with the 4.77. Also, how did you make your decision. At sometime in the future (after my wife gets over me buying the S2k this year), I would like to buy a sc like a vortech. How would 100+ extra horsepower effect drivability with the 4.44 and 4.77 gears? BTW, I typically drive on back roads with 50-55 mph speed limits and highways.
