4.77 GEARS
Old Apr 14, 2005 | 10:00 AM
2000celicaspeed's Avatar
Default 4.77 GEARS
Would you recomend these for a NA application? I may go FI later if i do are these too much? Would i be better off going with the 4.57?
also what kia, or mazda did the 4.77 come in? i used the search funtion but couldnt find the info
Old Apr 14, 2005 | 03:02 PM
Slows2k's Avatar
Moving to S2000 talk. You'll have more response there.
Old Apr 14, 2005 | 03:25 PM
spapdx's Avatar
I have heard that the gears are great for both, NA and FI. Not sure on your other question....
Old Apr 14, 2005 | 03:59 PM
papa5murf's Avatar
4.77 is to much for an FI application....
and depending on how much power you're going to have.... will depend on the other gears..... if you're going for a little boost.. around 350rwhp then 4.57's should be ok.... if you're going a little higher then that... 4.44... and if you're going all out on power.. then keep the stock gears....
Old Apr 14, 2005 | 05:03 PM
Wisconsin S2k's Avatar
The 4.57 are also stronger than the 4.77's. Another reason to use those instead if you are going to go FI.
FWIW I have the 4.57's and I can put 4-5 cars on a stock S2k from a stop to 90.
Old Apr 14, 2005 | 05:25 PM
terd ferguson's Avatar
I say F it. Get the 5.1's.
Old Apr 14, 2005 | 08:59 PM
YellowS2kPwr's Avatar
yet to be proven
Old Apr 15, 2005 | 01:33 PM
No I've proven it. Just not to you personally. You just haven't seen it, but that doesn't mean I haven't done my own runs. I've run 2 S2000's so far, the results the same.
Old Apr 15, 2005 | 04:14 PM
StinkyTofu's Avatar
5.1 for sure
S2K_1987
Feb 25, 2008 11:48 AM
mr_grand_prix
Dec 11, 2005 05:22 AM
ahbongkadah
Nov 24, 2005 05:56 AM
kinetica
Sep 24, 2005 12:17 PM
X_s2k_X
Apr 15, 2004 05:44 PM
