7500 RPM's?
Old Nov 7, 2000 | 09:43 PM
bguernsey's Avatar
Can someone tell me if there is any known reason why the S2000 might cut out when cold and hitting around 7500 rpm in a low gear (1st or 2nd)??
I know its setup to cut out at 9000 rpm's, but 3 times now I took off very quickly, watching the RPM's and had the throttle disengage at 7500 rpm's. Either my tach is wrong or the sensor is cutting off too early?
Has anyone experienced a similar problem?
Old Nov 7, 2000 | 09:47 PM
krazik's Avatar
Administrator
do a search for 3 bars.
Your car has a cold rev limiter at 6.5k rpms, until it is (almost) 3 bars warm.
Old Nov 7, 2000 | 09:48 PM
ricosuave's Avatar
you're not warmed up to 3bars.
it's designed to cut to prevent engine damage with the vtec
Old Nov 7, 2000 | 09:49 PM
gregstevens's Avatar
Banned
It's not a problem, it's there to prevent over-rev'ing on an engine that isn't warm enough. You need to have 3 bars on the temp gauge before you should hammer on it...
Warm that engine before you pound on it. That means, get three bars...get all the oil, water and other temps up to speed THEN hit it...before then, you are not doing any good to your engine at all...!!
Old Nov 7, 2000 | 09:59 PM
Harvey Jr's Avatar
It's not a problem. The ECU is programmed to use a rev. limiter when the engine is cold, and the VTEC change over will not occur. It's best to wait for the temperature gauge to read three squares or bars before running into VTEC range. I usually stay below 5000 RPM when the engine is cold.
This is a well documented occurrence.
Paul
Old Nov 7, 2000 | 10:00 PM
Harvey Jr's Avatar
Oops, not quick enough. I was reading the owners manual to see if it was in there to give a page refference number.
Paul
Old Nov 8, 2000 | 03:34 AM
Red_s2k's Avatar
I am guesing that was answered to the satisfaction of all new 01' s2ker's.
Old Nov 8, 2000 | 05:13 AM
bguernsey's Avatar
Thanks everyone. I didn't know that, but I was hoping it was due to the cool engine. It sometimes takes a lot of go to take off quick enough to get out of my companies parking lot without getting hit :-) Now I'll remember to warm it up some. Thanks again..
Byron
(actually a 2000 S2000 owner)
lotus7racer
Apr 23, 2009 04:20 AM
rambo1
Jan 19, 2007 12:20 AM
K4RL
Aug 3, 2006 12:18 AM
Dragon Curve
Oct 15, 2004 04:39 AM
TunedS2000
May 9, 2004 09:39 PM
