Aftermarket XM with 2004 Head Unit
Originally posted by Rhino Driver
One more "ttt"--don't tell me that with all of the technical knowledge out there, that no one has the answer to what should be a simple question...
Help a bro out...
Thanks
Rhino Driver
Help a bro out...
Thanks
Rhino Driver
I'm guessing if any reciever would work it would be Alpine. Blitzsafe and Peripheral make adapters, you might give them a call.
Just for grins I shot Blitzsafe an email asking what the stock HU/factory harness/aftermarket XM receiver interface might be...or if they're working one...
We'll see...
Rhino Driver
We'll see...
Rhino Driver
Iv'e got a .PDF file of the XM installation instructions. I'm not sure how to post them. It appears that the XM reciever uses the same bus cable that the factory CD changer has. I don't know of any XM reciever that uses the same connector. (I freely admit to not knowing much about XM recievers) I have installed the Honda XM reciever on a Pilot (which is FM modulated) The accessory reciever is identical to an off the shelf Alpine unit. I'm not sure if Honda stuck with Alpine for the S. Most Honda audio systems are supplied by Alpine and Panasonic.
If it is compatible with Pioneer XM tuners then you should be able to use the following:
GEX-P900XM
GEX-FM903XM
GEX-P910XM
GEX-FM913XM
and you will need a CD-IP600 IP-Bus cable to connect them and an XM antenna.
I bought a Pioneer ready HU, a GEX-P900XM, and a CD-IP600 for my Miata so I am assuming that if the 2004 S2000 HU is made by Pioneer that the Pioneer tuners that I listed will work, but I cannot verify it.
Hope this info helps.
Kirk
GEX-P900XM
GEX-FM903XM
GEX-P910XM
GEX-FM913XM
Kirk
