Anyone put their windshield tape back ON?
Tape can be installed very easily, you can use the same concept as for tinting windows but even better because you do not have to cut the tint. You will need the following items,
Squeegee ( spelling correct ? )
Soapy water Baby shampoo mixed with water works best
Spray bottle
Hair Dryer
If you do not have a spray bottle you can apply the soapy water with a sponge.
Wet the entire surface you want to apply to with the soapy water,
remove the plastic in the tape revealing the adhesive, wet the adhesive side of the tape.
Apply the tape to the suraface while it is still wet. If the surface starts to dry before you can place the tape wet it some more. Line up all the pieces while it is still wet. You can align it really easy because the tape will not stick while it is wet.
When you have all the pieces lined up correctly use the Squeegee and take out all the water and air bubbles. Use the hair dryer to heat up the tape ( this will dry the adhesive and make it stick) after that you are done.
Spray bottle
Hair Dryer
Originally posted by S2000PILOT
Nice Fog lights, your car must be birght with all those lights on at night
They only add a little light and of course, the HID's do it all.
Grills are before I had them powdercoated black by Coastal Metals.
