AP1 OEM lip, how much does it add?
I want to add a OEM lip, and I am lowered on RSR Ti2000s, how much does that OEM drop the front end? If its a lot I might just wait until I get rims (after these new S03s get bald)
Also, will adding 17's and say 40 series tires raise up the car slightly?
Also, you haven't provided enough information for me to tell you if your car will be raised or not with the tires. Idk how wide your tires are, so 40 series means nothing to me. 205/40, or 265/40? There's a difference in sidewall height there.
Well, I just wanted to know in general, when people get 17s with the ''general'' 17'' tire if it will raise the car. What I run 225/50/16s in the back on stock 16'' rims. Is that even the right size for this car? To make it simple, are the AP2's with 17s diamater, the same size as the AP1 16'' diameter?
Another way of putting it would be:
Are the 17s larger or does the 1'' in rim size equal out with the shorter sidewall?
