Bad Harmonic w/ Comptech SC -> Is this normal?
Old Apr 3, 2001 | 09:51 AM
  #131
RT's Avatar
RT
[QUOTE]Originally posted by hecash
[B]RT:
I have recently sent a PM to you about this version of check valve.
Old Apr 3, 2001 | 02:23 PM
  #132
SilverSurfer's Avatar
Dyno is set for tomorrow (Wednesday, April 4) at 12:00PM PST. I will have my car dyno'd with Comptech latest check valve and comptech exhaust, Dave will dyno his with ghostbooster fix and then with the latest check valve. We should be able to get some good numbers to show comptech. I believe dave has rigged up something so he can easily switch from electronic fix to check valve fix. We are trying to eliminate as many variable as we can...i.e. different cars, exhaust etc, etc. Therefore if we dyno dave's with both fixes everything is constant except for the check valve or electronic fix. I wont be able to post results until late tomorrow night but dave might be able to earlier in the evening.
Old Apr 3, 2001 | 02:46 PM
  #133
RT's Avatar
RT
Been thinking (ah oh, not that) but I'm not so sure the dyno will show much between the latest check valve and the ghost pack. Reason being the newest valve breathes enough, no big pressure drop across the valve, hence no sustained pressures above atmo seen by the MAP sensor.
The problems I'm seeing with the newest check valve are all transients, non steady state throttle position problems.
With dyno pulls at full throttle from sub VTEC, I'm not sure how much diff there will be.
Don't get me wrong, I hope there's a huge difference, then I've got some more power to be had in the near future
You guys ROCK!
Old Apr 3, 2001 | 03:10 PM
  #134
[QUOTE]Originally posted by RT
[B]Been thinking (ah oh, not that) but I'm not so sure the dyno will show much between the latest check valve and the ghost pack.
Old Apr 3, 2001 | 03:16 PM
  #135
RT's Avatar
RT
use the schwarts (Good Luck)
[Edited by RT on 04-03-2001 at 04:55 PM]
Old Apr 3, 2001 | 04:00 PM
  #136
shaner's Avatar
I don't know guys... I just installed Shad's first MAP boost revision with the external blow-off valve (most of you are getting your second MAP revision in the mail) and I got no hesitation and absolutely the smoothest acceleration right to 9000rpm.
In fact the acceleration was so smooth and fast, the cop witnessing the event congratulated me with THREE tickets. They were looking in their code book for everything they could write me a ticket for. I am surprised I wasn't arrested.
I hate my supercharger.
Old Apr 3, 2001 | 04:13 PM
  #137
rocketman's Avatar
just a note on dynoing:
before I dynoed my car (w/original check valve), I had not felt any hesitation. On the dyno, however, at WOT, it was clearly obvious that something wasn't right - steep drop in power at 6800 rpm (ECU threw a code?). the dyno may very well show a difference, even if it is not felt.
Old Apr 3, 2001 | 04:39 PM
  #138
RT's Avatar
RT
rock, I agree 100%, just didn't want people to get their hopes all up and sh!t.
Based on our in depth understanding of the problem, and what specifically causes it, I don't think the dyno will show huge power gains, but like Keith mentioned, might smooth out some of the transitory anomalies ( them are big words).
Old Apr 3, 2001 | 04:40 PM
  #139
2x6spds's Avatar
[QUOTE]Originally posted by shaner
[B]I don't know guys... I just installed Shad's first MAP boost revision with the external blow-off valve (most of you are getting your second MAP revision in the mail) and I got no hesitation and absolutely the smoothest acceleration right to 9000rpm.
Old Apr 3, 2001 | 04:48 PM
  #140
RT's Avatar
RT
LOL
or not..........
I see definite tendencies toward the dark side......
