Are Black Chrome Emblems smaller than stock?
Old May 19, 2007 | 10:25 AM
yungjoc's Avatar
Default Are Black Chrome Emblems smaller than stock?
I just bought a set from member "Hoa" and he told me they were made for an s2000, but he decided to not use em. I tried test fitting them on my car, but they are smaller and the holes don't line up with the new clips unless I take out the white things. Is it suppose to be like this?
Old May 19, 2007 | 10:35 AM
AJ PwR's Avatar
I can't remember the rear one but the front is a lil smaller.
Old May 19, 2007 | 10:52 AM
yungjoc's Avatar
am i suppose to remove the white clips?
Old May 19, 2007 | 10:55 AM
F20C PWR's Avatar
you would have to drill new holes in order for the front emblem to be attatched, the rear should go in perfect. I have the same ones, i didn't want to drill my bumper so i just put 3M tape and it works PERFECT. All you have to do is get a razor blade and cut the tabs off and cut small pieces of 3m double sided tape in back of the emblem try to hide as much as you can push it against the car hold it for a bit.. It's on their pretty strong and mine has been on about 5 months already.
Old May 19, 2007 | 11:44 AM
yungjoc's Avatar
anyone know how to remove the front emblem off the bumper? doesn't seem to want to come off
Old May 19, 2007 | 11:56 AM
Just Guy's Avatar
You do not have to drill new holes!
I am going to guess that his car was an 00-01. Those badges are a little smaller than badges made for 02+ and the holes won't line up right in the front OR the back. You simply have to take off the pegs on the back of the badge and just use the adhesive tape to keep them on. It will look fine and the tape will hold, I had to do this myself. Just make sure you line up the badge straight
Old May 19, 2007 | 12:02 PM
yungjoc's Avatar
the pegs in teh back lined up after i took off the white clips, but i'm having a hard time taking off the front emblems. they just won't come off and theres not much room in the back of the bumper. seems like there is a washer clip holding it in place.
Old May 19, 2007 | 04:20 PM
Ustemuf's Avatar
use fishing line and run it behind the emblem and then pull from both sides of the line toward you to pop it off.
usafstud
Apr 9, 2018 05:10 AM
pbarnicle
Sep 14, 2016 09:51 AM
Carbon Blue
Jun 23, 2010 08:09 PM
dthondatune
Dec 13, 2007 03:50 PM
mhs2k
Jan 30, 2004 04:44 PM
