Break lose upon VTEC?
Old Jan 22, 2009 | 06:29 AM
s2kobsession's Avatar
I can go sideways with vtec in 1st gear during the heat of the summer
fun isn't it!
it's most likely your tires though. As mine go bald I begin to go REALLY sideways ahah
lately the new dunlop direzza's have been really popular. They have been compared to the re01r's and azenis. Check them out
Old Jan 22, 2009 | 06:47 AM
dparm's Avatar
^ When he says Direzzas, he's talking about the Star Spec model, FYI.
Tire Rack has them beating the RE-01R and R-S2 in every area.
Old Jan 22, 2009 | 06:51 AM
vtec9's Avatar
You should see how much traction I get with snow tires in 15* weather I wonder what people think when my ass end breaks loose when I'm going up a up hill?
Old Jan 22, 2009 | 07:41 AM
hariku821's Avatar
Are your tires cold when you do this? If you have been driving for awhile and then hit vtec does it still happen?
Old Jan 22, 2009 | 07:49 AM
Ks320's Avatar
if your tires look okay, and road conditions are decent (ie road isn't cold in winter) ... check the tire pressure and alignment
I only found my car breaking losing when the road's cold
Old Jan 22, 2009 | 07:59 AM
CKit's Avatar
Also make sure you really look at the inside part of the tire from the rear. With camber, you can wear out the inner edge while the outer looks "fine."
If money is tight, consider getting a longer-wearing tire.
Old Jan 22, 2009 | 08:11 AM
JDMPONY00's Avatar
It's tires. It's 20-30 far. where I live right now. I ocassionally get the car out when it's sunny and no salt. It's pretty fun makes you feel like the car has some power when it starts kickin sideways at 4k WOT lol.
Old Jan 22, 2009 | 08:34 AM
jasonw's Avatar
1. Make sure road is dry and air is > 45 degrees F - $ free
2. Check tire pressure - $ 0.75
3. Alignment - $70 to $90
Replace tires when the tread depth is low, but this is not the problem if the road is dry. Also, RE050 is a relatively longer wearing tire.
</thread>
Old Jan 22, 2009 | 08:37 AM
hirev's Avatar
if you are new to your s2000, they do that, the weight is centered so that when you are mid turn and you goose it the rear begins to spin out...just give it gas gradually when in a turn and then power out just as your rear is through the apex. sure balding tires will do it too and wet weather and cold, but power applied at the wrong time will spin...
Old Jan 22, 2009 | 08:56 AM
Mr. Francesco's Avatar
Temperature, Tread wear and Tire pressure are the stated variables above that you need to check.
