cf hood
Old Oct 31, 2004 | 08:57 AM
aodmisery's Avatar
Default cf hood
i been wanting to buy a cf hood for my s but i really dont know much about them. whats the good brands? i been looking at the vis and seibon ones are those any good? i dont want anything to flashy just an oem look.
Old Oct 31, 2004 | 10:42 AM
SIIK2NR's Avatar
What is "cb" hood?
Old Oct 31, 2004 | 10:50 AM
HeelandToe's Avatar
Do you mean a "CF" (carbon fiber) hood.
i been wanting to buy a cb hood for my s but i really dont know much about them. whats the good brands? i been looking at the vis and seibon ones are those any good? i dont want anything to flashy just an oem look.
These hoods are nothing but flashy even with the OEM style.
Old Oct 31, 2004 | 11:17 AM
beanolo's Avatar
unless your car is black ...
theres really no purpose to it... i mean.. weight reduction? seriously it doesnt make a huuuge diff..
Old Nov 1, 2004 | 05:47 PM
JustJustin's Avatar
How about for performance/cooling (for the vented hoods) or to fit your aftermarket intake?
Mugen, Amuse/Jays and others make good CF hoods.
-Justin
Old Nov 10, 2004 | 06:57 AM
Tony Yeung's Avatar
I have one for sale. OEM Carbon Fiber hood from Fiber Images. Check it out here
Old Nov 10, 2004 | 09:44 AM
papa5murf's Avatar
i wouldn't buy an oem style cf hood.. not worth it.... some are even heavier then your stock hood... ... if you get one you should get one with some vents.. it'll help release heat from your engine bay... you can also get them painted to match your car so they won't be as flashy...
Old Nov 10, 2004 | 12:23 PM
Black Nugget's Avatar
I have a OEM Style Seibon one that i bought used, it was more-so a great deal that caused me to want to get into it. being black its sorta sneaky sneaky.
by the way, are you an enthusiast or an owner?
Old Nov 10, 2004 | 12:48 PM
jerrypeterson's Avatar
Actually in almost all instances a carbon fiber hood will weigh more than the stock aluminum hood. The aluminum hood from the factory weighs a mere 13lbs. When removed from the car, you can pick the stock hood up off the ground using just your pinky.
Most of the carbon fiber hoods for our car are 20% heavier than stock. The only construction that would be of any weight benefit are the dry carbon fiber hoods with out ribbing. Pretty much a sheet of carbon fiber secured with hood pins. The weight savings is a whopping one to four pounds. Which makes a difference, but certainly not a difference remotely worth the expense. There are 300lbs of weight in our car that can be easily removed free of charge. This is a far better option than paying $500+ dollars per pound removed. That and you still need to paint the part to keep from looking like a knuckle-dragging buffoon.
myslow1
Apr 11, 2010 08:39 PM
Koski
Jan 31, 2009 02:04 PM
s2kshift9k
Oct 19, 2004 11:26 PM
K2S
18
Jun 16, 2004 10:49 PM
