Clunking noise pulling away
Old Apr 8, 2023 | 09:35 PM
Bobbyk56's Avatar
Default Clunking noise pulling away
Hi everyone,
was out in the car tonight and drove it pretty hard and had it sideways a little about 30mins into the drive my check engine light came on and I noticed that pulling away in first gear produced this awful noise from the rear of the car sounds like a horrible clunking sound and feels like somethings going to snap then once your going it goes away, all the up shifts on the gear box are smooth as usual but the downshifts produce a single loud clunk as I lift of the clutch, not as bad as pulling away in first gear sounds though just a single one and not a series of them, so cut the drive short tonight and limped the car home at 40mph as I was only 40mins from home, when I reversed on the driveway at home it’s smooth as usual no noises witch I found strange as I thought it would be the same as first gear, going to plug it in later today and see what codes it brings up and will update the post
thanks In advance for any info il try to get a video if I can just worried I might make it worse if I drive it again as I cruised home and only had to stop twice at traffic lights so didn’t need to use first gear other than that luckily
Cars a 2000 plate Ap1 jap import
Old Apr 9, 2023 | 09:12 AM
windhund116's Avatar
Rear wheel bearings?
Old Apr 9, 2023 | 09:23 AM
Bobbyk56's Avatar
Never thought wheel bearings I did fit a second hand hub the evening before I went out, and I’ve done a code reader and it threw up the 02 sensor code so guess il start there, going to get new cv joints as it was clicking before anyway if they both don’t sort it out guess il do wheel bearings
Old Apr 9, 2023 | 02:10 PM
Or just re-torque the rear axle nut. See if that helps get rid of the noise.
Old Apr 9, 2023 | 02:35 PM
Bobbyk56's Avatar
I have read about that on some threads here so going to do that this week when I do the other bits so hopefully will help with it
Old Apr 10, 2023 | 08:09 AM
Car Analogy's Avatar
... going to get new cv joints as it was clicking before anyway...
Don't get aftermarket cv axles! They're all horrible. Vibe city.
Either:
Swap inner axle cups (need to regrease during, messy job)
Get axle spacers
(If you do either of above, when eventually cv wears out again, can do the other. Then eventually do other again. Swap. Then spacers. Then swap back with spacers. Get 4 lifespans)
Buy new inner cv from Honda (same messy job as cup swap)
Buy new axles from Honda (only for ballers, $$$)
Old Apr 10, 2023 | 09:46 AM
Bobbyk56's Avatar
Either:
Get axle spacers
Thanks for info I’ve managed to find a local s2000 to me that was being broken for parts and I’ve bought the drive shafts of it as they were relatively cheap! And all the gators/cups seem to be in great condition so going to re-grease it before I put it on, and got a new 02 sensor to get rid of check engine light so hope fully be all okay
And thanks for mentioning axle spacers, I have a question about them as I was thinking of buying them to put them on the car with the new drive shafts but is it worth it? I’ve read that they help when the cars been lowered and mines been lowered about 20mm, weather what I’ve read is true or not I don’t know haha so question is shall I get them now or wait till I have a clicking problem again?
thanks for response everyone
Old Apr 10, 2023 | 10:17 AM
noodels's Avatar
Spacers worked on mine,but you have already got some s/h shafts to re-grease you will see condition of them and make your plans then.
Old Apr 10, 2023 | 10:54 AM
Bobbyk56's Avatar
okay Il hang back buying any and fit the new driveshafts with out them
Old Apr 11, 2023 | 03:31 AM
Apollo99's Avatar
I had this same issue, I just retourqued the rear axle nut and the problem was solved. If you keep driving it like that you’ll damage your wheel bearings and hub, be careful!
jaymz
Jul 3, 2020 05:37 AM
DaRkPT
Sep 22, 2016 12:46 AM
g.guess88
Apr 2, 2015 04:20 PM
blitz16v
Oct 16, 2007 07:03 AM
MDS2K
Apr 30, 2001 01:59 PM
