Do you A/C when top is DOWN?
Old Apr 20, 2002 | 09:49 AM
wantone's Avatar
Default Do you A/C when top is DOWN?
Man today is hot as a mofo. Just wondering, any ya'll A/C while your top's down?
Old Apr 20, 2002 | 10:01 AM
ferrariman's Avatar
Banned
i do sometimes, although when i do i feel stupid, and at the same time i am wasting money gas
Old Apr 20, 2002 | 10:02 AM
minboost's Avatar
yes, i do. why would you feel stupid? isn't it the same and top down w/ heat on?? i'm sure ALOT of ppl do that.
Old Apr 20, 2002 | 10:03 AM
DarioManfretti's Avatar
Hell no!! What would be the point of having the top down if you have to turn on the A/C?
wantone's Avatar
F-man, have you posted your pics of your new F355 Spider????
redbullet's Avatar
yeap I do. but it doesn't get to hot in New Hampshire..I use the heat sometimes too when the top is down!
Old Apr 20, 2002 | 10:51 AM
boyracer's Avatar
With the heat and humidity of Louisiana, there are some days you have to!! But it depends whether I'm driving in the city, with a lot of stop & go, and out doing some back road driving.
Old Apr 20, 2002 | 10:58 AM
stockae92's Avatar
no A/C
but i do turn the fan on sometimes ...
Old Apr 20, 2002 | 10:59 AM
Destiny2002's Avatar
I see no reason not to. Cold air "falls", so potentially using A/C should keep you cozy. Wearing white can help, too!
I don't like using A/C on a stick shift car "in town". The timing of the shifts is so much different with the compressor running than when it isn't, that I find it annoying and prefer to leave it off. (You never know whether the compressor is running or not, because it cycles on and off while operating.)
Old Apr 20, 2002 | 11:40 AM
scottrnelson's Avatar
Having the heat on when the top is down is NOT the same as having the air-conditioner on with the top down. You get the heat for free, but the AC actually takes a little bit of power.
If it's hot enough, I turn on the air conditioner with the top down, but side windows up. I don't consider that any more wasteful than having the AC on with the top up, since the air conditioner has to do exactly the same amount of work. On the day the accompanying photo was taken, the temperature hit 112 degrees in the Southern California desert. I was determined not to put my top up except for heavy rain, but without the AC, I probably would have died from heat exhaustion. With the AC it was reasonably comfortable.
