drive shaft spacer's
Old Aug 7, 2007 | 03:46 PM
114_ap2's Avatar
Default drive shaft spacer's
sorry i'm a noob to this, what does it do????
Old Aug 7, 2007 | 04:09 PM
slipper's Avatar
When you drop your AP1, there will be some play in the driveshaft. The spacers will take up the slack.
Since you have an AP2, you dont have to worry about these.
Old Aug 7, 2007 | 04:21 PM
stocky's Avatar
why not on AP2 ?!
Old Aug 7, 2007 | 04:24 PM
Trent06's Avatar
do you need spacers with eibach springs?
Old Aug 7, 2007 | 06:16 PM
negcamber's Avatar
There is a long thread in the "Under the Hood" forum, which analyzes spacers. Bottom line...more than likely neither the ap1 nor the ap2 need them.
They can be useful when you drop a higher milage s2k (ap2 included). As the inner CV gets more miles, a pattern wears into the bearing surface. When you lower the car, the roller bearing inside the CV shift and trammel between the old wear spot and the new. This causes vibration.
You can use a spacer to move the roller bearing far enough away from the old wear spot so that it will not trammel. You can also swap inner CV from right to left and vis versa to give a fresh bearing surface for the roller to ride on.
This is true for both the ap1 & ap2. To stop the myth...the ap1 & ap2 uses the same axle (including inner cv). The width of the ap1 & ap2 diff from flange to flange is exactly the same.
Old Aug 7, 2007 | 06:34 PM
stocky's Avatar
thanks for clearing this up!
Old Aug 7, 2007 | 07:13 PM
chairmnofthboard's Avatar
I don't think you need them. the suspensions always traveling anyways.
If you want I can make you a set for $150! lol but you don't really need them IMO.
Old Aug 8, 2007 | 06:48 AM
114_ap2's Avatar
thanks guys, thats 250 that will stay in my pocket
cmn
Sep 2, 2011 07:13 AM
bjeong1381
May 15, 2007 06:39 PM
bjeong1381
Mar 21, 2007 12:07 PM
frofro24
Jul 31, 2006 08:54 PM
