Drivers side window
Old Oct 13, 2005 | 05:14 PM
xviper's Avatar
Originally Posted by Kiefer74,Oct 13 2005, 06:43 PM
Thanx for the link x-viper. A quick and easy fix and everything seems to be working fine now. Hope it lasts, but if it continues I'll just take it in to the dealership. Damn, I hate dealerships!
This tells me that it's the regulator. I hope it lasts for you. In any case, for future reference, to figure out if it's the regulator or some other component that is related to the soft top function, see if the "auto-down" feature works. That is, DON'T hold the button the whole time. Just hit it once and if the window only goes down part way, it's the window regulator. If it goes down all the way but won't do it when you use the top, then it's in another component associated with the top function. It won't be anything to do with the main ECU.
Old Oct 13, 2005 | 05:18 PM
Kiefer74's Avatar
Sounds good...thanx again
edit: I was suprized to see how many other people had this problem!
Old Oct 13, 2005 | 06:55 PM
FearlessFife's Avatar
Mine does that occasionally.
Am I worried about it? No. If the window will still go down I am okay with it.
Old Oct 13, 2005 | 07:24 PM
44Runner's Avatar
there is a TSB on this problem. It is very common, happened to me and has been discussed on the board numerous times...
http://www.s2kcarolinas.com/library/tsb/pdf/a01-008.pdf
jeaent
Aug 13, 2005 11:01 AM
Cragspider
Jun 19, 2005 12:33 PM
oOweEe
Mar 30, 2005 04:36 AM
Dezoris
Nov 7, 2004 03:51 PM
Squeezer
Mar 21, 2001 06:03 PM
