drivers side window problem
Old Jun 18, 2005 | 07:39 AM
Cragspider's Avatar
Default drivers side window problem
Ok so when I go to put my top down the drivers side window only goes down a inch or so. I have to hit the down button to get it to go the rest of the way. Any ideas on whats wrong before I decied to take it to honda.
Bryan
Old Jun 18, 2005 | 09:55 AM
CrAzYNeSs's Avatar
Member
Its a TBS take it to your dealer and see if they can do it under "goodwill" or if you still have warranty; it'll be covered. Good luck
-Jeff
Old Jun 19, 2005 | 09:50 AM
Cragspider's Avatar
Thanks, unfortunatly its out of waranty. But I will take it in and see what they can do.
Bryan
Old Jun 19, 2005 | 12:30 PM
PJK3's Avatar
it's a TSB. i'm on my 3rd right now. it was covered under HondaCare.
also -- there's a 'trick' to get the problem to temporarily stop. ymmv.
start the car.
-roll the window all the way down, release the switch, then down again, and hold it for 10 seconds or so. you'll hear a slight click.
-roll the window all the way up, release the switch, then up again and hold it for 10 seconds or so. you'll hear another slight click.
this should reset the window regulator and help. if you're not hearing the clicks, you're not holding long enough.
after it goes up and clicks, you won't be able to roll down the window for about 30 seconds.
i hope i'm remembering this right. i thought this post used to be in the FAQ, but i can't find it now.
Old Jun 19, 2005 | 12:33 PM
PJK3's Avatar
found it...
if these directions differ from mine... use them. mine were from memory.
https://www.s2ki.com/forums/index.php?showtopic=131795
the fan
Apr 30, 2010 11:39 AM
wing
Nov 13, 2005 12:09 PM
jeaent
Aug 13, 2005 11:01 AM
vader1
Aug 1, 2005 12:23 PM
Venomous S
Jul 8, 2003 09:48 AM
