Engine Choke?
Old Jun 8, 2002 | 10:55 AM
urpow's Avatar
Default Engine Choke?
I have had this problem about 3 times on the road... so I was wondering if its normal or if there is a serious problem w/ my 02 S2000.
It happens when I am pushing the Engine, ie shifting at 8300 rpm, and not at 4000-5000 rpm when in first gear. When I am accelerating, all of the sudden there is a jerk backwards as if the car was breaking (or engines choking) at around 5000-6000 rpm. It feels like tranmission braking (big jerk backwards), with the exception that I am not even using the clutch (except in shifting, but I don't shift till 8000 rpms). After this happened in first gear.. I shifted to second gear and began accelerating rpms again... happens same thing at 5000-6000 rpms.
After that incident, I began normal driving... After a few miles and minutes.. I pushed the engine again.. and all was normal.. vtech kicked in at 6000 rpm as usual.
I believe that maybe the engine was still "cold" for a push. However, it was.. a pretty hot day today.
My S2000 has 700 miles in it.
What is your opinion? Normal or serious? Are there side effects?
Thanks in advance.
Old Jun 8, 2002 | 10:59 AM
DarioManfretti's Avatar
The rev limiter kicked in because the engine wasn't warmed up to three bars. Just because it is warm outside, doesn't mean the engine is warmed up. Next time, wait until you get three bars before going into VTEC.
Old Jun 8, 2002 | 12:09 PM
pellisS2k's Avatar
This question, and the answer really should be in the FAQ, but I didn't see it.
Old Jun 8, 2002 | 01:38 PM
xviper's Avatar
I've added this to the "new" FAQ that Cthree is working on.
Old Jun 8, 2002 | 03:48 PM
VTR_Gary's Avatar
Just like a woman, ya have to cuddle and smooch for a bit before Gittin' Bizzy...
Be gentle until you have 3 bars of temp. There are many reasons, among them, pistons aren't round when cold. They're slightly oval. When they warm up, they become round. If you rev the snot out of any car when cold, you'll cause premature engine wear...
Saltymooring
Apr 2, 2015 10:51 AM
jameswh0
Dec 19, 2005 03:09 AM
rastamansar
Nov 29, 2003 07:27 PM
seiji
Aug 24, 2003 06:45 PM
S2Krzy03
Aug 16, 2003 05:12 AM
