Engine stuttering when dropping to idle?
Old May 14, 2005 | 09:14 AM
  #21
kennyr's Avatar
Originally Posted by Wisconsin S2k,May 14 2005, 03:13 PM
considering my S2000 did this even when it had a mere 600 miles on the odometer, i am doubtful this is a permanent solution. might work for a couple days, but that's my opinion. the experts of s2ki says it's the learning ECU.
also, do NOT use brake cleaner. that is VERY corrosive and can actually remove some of the protective coatings inside your ITB/manifold.
Yeah, mine has done this as well. I noticed it the first time at 400 miles. It has never bothered me, cause it only happends if i rev the engine high while in no gear. Then when its about to start idling at 1krpm it drops to 800-900 for a second or so then goes directly back up to 1krpm.
Old May 14, 2005 | 05:19 PM
  #22
landfighter's Avatar
I have heard that some stock intakes have a special coating similar to k&n filter oil, that is there to catch dust and small particles that pass thru the filter. My beater(F-150) has a sticker on the throttle-body that says DO NOT CLEAN. I have looked inside and it was somewhat dirty, I am thinking about cleaning it someday and recoating it with oil. I am not sure how much this helps, but should catch more than a dry/un-oiled intake.
p.s any thoughts welcome
Old May 15, 2005 | 04:25 PM
  #23
gbaker's Avatar
You should be careful what you run through your engine. You could damage your cataclysmic converter. Make sure you use stuff that says its compatible. I suspect brake cleaner is not. But newer carb cleaner sprays probably are OK.
Old May 15, 2005 | 06:43 PM
  #24
Elistan's Avatar
Simply reducing the amount of hot air in the engine bay did the trick for me. <shrug> I don't see how this could work, but if you see results, good on ya.
Old May 15, 2005 | 06:58 PM
  #25
boiler's Avatar
As I sat here and read this thread, one thought kept surfacing: when the cleaner was sprayed into the throttle body, it must have cleaned the MAP sensor that is mounted on the top of the throttle body. I wonder??????
I agree with the possible "cataclysmic" results on the "catalytic" converter if you use brake cleaner. I would stay with carburetor cleaner, which should be safe for your catalytic converter
blink962
Oct 2, 2016 12:30 PM
OMCMT
Jul 1, 2014 06:26 AM
lukedon
May 12, 2008 02:37 AM
Ahnold
Nov 5, 2007 04:04 AM
Type Rik
Mar 25, 2006 09:53 AM
