Espelir springs and alignment
Old Aug 30, 2007 | 12:29 PM
zbrewha863's Avatar
Default Espelir springs and alignment
First, I did a search and this question has been asked before, but not answered.
I have a set of Espelir ASD springs on the way, and I am wondering about alignment ... can you align them back to stock specs (or say, stock UK specs) without a kit?
Also, I think there might be some debate as to how low they actually drop -- I have seen 0.8 front/1.3 rear, 1.3 all around, and I have also seen that after they settle in a week or so they drop like 2" all around (older threads). So was this just a problem with older Espelir springs that has been fixed now?
Should I plan on buying front and rear anti-bumpsteer kits?
Thanks!
Old Aug 30, 2007 | 03:36 PM
RED MX5's Avatar
Up to an inch or so you'll have no trouble getting the car back to stock specs, or to UK specs, IF you have an alignment guy who know's what he is doing.
A 1" drop also does not make a significant difference in the roll steer profile (aka "bump steer profile"), so if you're not having bump steer issues now you shouldn't have them after the drop. After a small drop, you're probably more likely to run out of suspension travel and have stability problems becasue the suspension is hitting the bump stops than you are to have a major bump steer issue.
If the drop is over an inch, you're on your own (IOW, I'm just not sure ).
Old Aug 30, 2007 | 03:42 PM
QuikSilver00's Avatar
yes you can get it aligned. Espelirs will drop you more than an inch after they settle. An alignment fixed my bumpsteer problem.
Old Aug 30, 2007 | 05:29 PM
zbrewha863's Avatar
Thanks for the advice guys, what does IOW mean?
Really what I was getting at with the question is whether or not I would need to buy bumsteer kits, I didn't think so b/c it's a pretty mild drop but it's always better to make sure
On a side note, I just got my Blitz Type 01s put on tonight, so pics will coming soon
Old Aug 30, 2007 | 07:15 PM
RED MX5's Avatar
IOW = "in other words"
The steering over bumps that results from misalignment is not the same as bumpsteer that is corrected with a BSK or steering rack relocation. LOL, the name does make it sound like the same thing, but it's really not.
Old Aug 30, 2007 | 07:45 PM
RED MX5's Avatar
I don't think you can be sure when it comes to the AP1 roll steer and associated potential for bump steer. Like everything else, it's a tradeoff, and if the trades suit your driving style and venues then you probably want to leave it alone, but if it causes you grief then you probably want to change it. Opinions vary, for good reasons, so you really need to drop the car, drive it a while, and decide for yourself. It's also better to change one thing at a time.
Old Aug 31, 2007 | 08:43 AM
zbrewha863's Avatar
Very true, plus I have to wait a couple weeks to get it aligned anyway. The other reason I was concerned about the front BSK is that I've heard the Espelir's can drop your car anywhere from 0.8in to 2in in the front, and with the front kit you just get a different-sized spacer, so I would need to know the actual drop first before getting the front BSK anyway.
Old Aug 31, 2007 | 01:53 PM
RED MX5's Avatar
I'm only dropped an inch in the back and a little over an inch in the front, so I really don't know what additional issues you might have after a larger drop. I just know that most of the problems people warned me about turned out not to have any real basis. Honestly, I couldn't live with the car on the street if it was any lower than it is now. Some speed bumps are big enough to scrape the frame and some driveways are too steep to turn into, so there are some places I just can't drive the car now. Of course that's true even at stock ride height, but every little bit that we drop just makes it worse.
My next suspension mod is going to be an adjustable FSB (Gendron) that we'll probably be installing in October. The after I wear out the set of S02's we just put on the car I'll probably try a set of Pilot Sport Cups. Probably going to be like starting all over when it comes to sorting out the handling after the tire upgrade, but that's the kind of thing that keeps this all so interesting.
rrounds
Aug 25, 2013 11:15 AM
Danwolski
Sep 30, 2012 05:55 PM
Broken2G
Apr 13, 2008 09:56 PM
importkid
Dec 10, 2007 05:17 PM
CyBerNeo
May 24, 2005 02:50 PM
