First Rock Chip
Old Aug 18, 2001 | 12:22 AM
redleader's Avatar
Default First Rock Chip
Despite stongard, a stray rock managed to strategically place a chip on my driver's side fender, just above where the stongard ends. Anyone have a good method of fixing this? I think I read somewhere here a really good and detailed step by step instruction on fixing paint chips (using the manufacturer's touch up paint).
Old Aug 18, 2001 | 12:22 PM
Forrest2b's Avatar
Check the FAQs for a detailed set of instructions.
https://www.s2ki.com/faqs/
Hope everything goes well
Old Aug 18, 2001 | 07:49 PM
lucid's Avatar
Assuming its down to the metal...
Use a sanding stick (looks like an eraser) to get any loose particals out
Get a 2" wide piece of masking tape and use a single hole punch out the middle. Lay it over the chip hole.
Use a sewing needle to work a tiny drop of primer to the chip and work it in the chip hole.
In a glass container take your touchup paint and mix 1 part paint to 1.5 reducer (not thinner). you only need a small amount.
Use a clean hypodermic syringe to slowly inject the paint in the chip. Do a thin coats, dont fill the chip up in one shot. Flash time is probably like 10-20 mins depending on the reducer. The reducer should allow it to bleed into the surrounding paint. If you do it right you won't have to wet sand it.
dfvs2k
Jul 28, 2010 03:38 PM
ProV1
Mar 20, 2007 06:53 PM
USCstudent
Jan 12, 2005 06:43 PM
JLR1969
May 27, 2004 12:05 AM
VinceD
Dec 18, 2002 02:52 PM
