Front License Plate HELP?
Mine has been ziptied to my front grille since my car was new (8 years). I just trimmed a little of the plate off the top and bottom, then took a smal strip of black duct tape and covered the edges of the plate to prevent it from scratching my car. Ziptied to the front grille, I've never had a problem with it. Never been stopped, and it's never overheated.
Originally Posted by dirtykoala,Jan 12 2011, 02:44 PM
zip tie it, get the ticket signed off, cut the zip tie.
Slimline personalized plates, I used the OEM bracket off the factory license plate plastic holder, bent it to locate the screw hole central mounted, then drilled a new hole in my license plate (central). I have a zip tie thru each corner hole of the lp. I stuck 2 layers of sticky back rubber near the behind lower edge of the lp to stop rubbing and bring the lp out and vertical rather than slanted. Am able to the clip the clear lp protector over the lp.
Originally Posted by redgs4,Jan 12 2011, 02:05 PM
I got my ticket for no front plate back in September (on 237). I have been running with this tow hook mounted plate holder since. I went front plate-less for 10+ years with my modded GS400 and was never stopped.
http://www.rhoplate.com/RPHA03.html
Works well for me. Easy to put on and take off and lot's of adjustment.
Originally Posted by thomsbrain,Jan 12 2011, 11:23 PM
I hate my front plate, but I still run it because I don't want to give them any extra excuses to pull me over.
