gears grinding at high RPM
Old Mar 2, 2004 | 05:19 PM
tygac's Avatar
Default gears grinding at high RPM
Hey everyone. Im an experienced manual driver but not knowledged much about trans, clutches, etc. The problem is, once in a while shifting from 1st to 2nd at high rpms, my gear grinds and no i didn't power shift. Is my clutch slipping? Thanks for your help.
Old Mar 2, 2004 | 05:22 PM
ideugene's Avatar
what year do you have? i know that was a bigger problem with the older year models
Old Mar 2, 2004 | 05:30 PM
RazorV3's Avatar
no it doesn't mean your clutch is slipping. it just means your 2nd gear itself or the 2nd gear synchro is in bad shape. there was a TSB on the older s2000's.
a slipping clutch is where the engine speed does not increase linearly with vehicle speed.
Old Mar 2, 2004 | 05:39 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You could have a simple dis-engagement issue, I'd start by changing the clutch fluid and adjusting the play of the clutch pedal pushrod.....has worked for a few cases of mine.
Rio Sunset
Mar 6, 2015 03:21 PM
planeman01
Nov 30, 2011 02:50 PM
hshiznit
Nov 12, 2010 12:06 AM
Phantom
Jun 19, 2001 08:11 AM
